PerformClick() on EpiButton issue
Let me know if you want me to send you my version (the xml customization
file), its currently deployed and works well. We are on version
8.03.409a...
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of drew.pete
Sent: Monday, September 20, 2010 8:14 AM
Subject: [Vantage] Re: PerformClick() on EpiButton issue
Rob,
Thanks for the tip. I tried it but sadly that didn't work either. I know
it's identifying the button correctly it's just not executing the method
PerformClick(). Hopefully I can get at it again later today.
Thanks again,
Drew
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
Bucek" <rbucek@...> wrote:
> Two things I did to make this work..
> Define your custom button in a form load event, for example..
> Private Sub StartProdForm_Load(ByVal sender As object, ByVal args As
> EventArgs) Handles StartProdForm.Load
> '// Add Event Handler Code
> btnOK =
CType(csm.GetNativeControlReference("025fc115-fee3-4973-946e-ba209189d62
> e"), EpiButton)
> End Sub
> Then...
> Change --
> e"), EpiButton).PerformClick()
> To
> btnSetupOK.PerformClick()
> HTH
> Rob Bucek
> FAX: (715)284-4084
Behalf
> Of drew.pete
> Sent: Thursday, September 16, 2010 4:06 PM
> Subject: [Vantage] PerformClick() on EpiButton issue
> So I have a button on a separate tab in MES that I would to use to
> invoke the "OK" button on the main MES tab in the End Activity form.
I'm
> using the custom button click event as a trigger. Here is the
following
> code I'm using. When I click my custom button it does not
performclick()
> of the other button like it should. I know that the event trigger is
ok
> and that I'm using the GetNativeControlReference because I checked the
> text property of that declaration and it came back ok.
> Private Sub btnSetupOK_Click(ByVal Sender As Object, ByVal Args As
> System.EventArgs) Handles btnSetupOK.Click
> '// ** Place Event Handling Code Here **
> 'Messagebox.Show("Button was clicked")
> End Sub
> Any thoughts?
> Thanks,
> Drew
So I have a button on a separate tab in MES that I would to use to invoke the "OK" button on the main MES tab in the End Activity form. I'm using the custom button click event as a trigger. Here is the following code I'm using. When I click my custom button it does not performclick() of the other button like it should. I know that the event trigger is ok and that I'm using the GetNativeControlReference because I checked the text property of that declaration and it came back ok.
Private Sub btnSetupOK_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnSetupOK.Click
CType(csm.GetNativeControlReference("025fc115-fee3-4973-946e-ba209189d62e"), EpiButton).PerformClick()
End Sub
Any thoughts?
Drew
Crap, almost forgot...
Also in the module script section make the following declaration
private withevents btnSetupOK as epibutton
Rob Bucek
FAX: (715)284-4084
Of drew.pete
End Sub
Any thoughts?
Drew
btnOK =
e"), EpiButton)
End Sub
Then...
Change --
To
HTH
Rob Bucek
FAX: (715)284-4084
Of drew.pete
End Sub
Any thoughts?
Drew
Rob,
Thanks for the tip. I tried it but sadly that didn't work either. I know it's identifying the button correctly it's just not executing the method PerformClick(). Hopefully I can get at it again later today.
Thanks again,
Drew
> btnOK =
> e"), EpiButton)
> End Sub
> Then...
> Change --
> To
> HTH
> Rob Bucek
> FAX: (715)284-4084
> Of drew.pete
> End Sub
> Any thoughts?
> Thanks,
> Drew
