Physical inventory in E9 ( same as V8?)
> > Questions:
> > 1. General pitfalls?
> Make sure you click Start Count on the day you want the totals posted.
Just a small clarification here: we don't click "Start Count" until we
KNOW that any outstanding transactions have been completed. Clicking
"Start Count" takes a snap-shot of the inventory at that point. After
the count is entered, the DIFFERENCE between the count and snap-shot
qty is posted as an adjustment. So you want to make sure that your
inventory values at the time of the snap-shot are at a quiescence*
point.
Mark W.
* Five points in the game of life for using "quiescence" in everyday
conversation.
Good Day:
RE: Physical inventory in E9 ( same as V8?)
Has anyone done a full. physical inventory in E9 ( maybe same as
V8?).
We need to do one, for the first time, in E9 on 4/30.
We were on manage-2000 last year and did not use their system.
Questions:
Flow:
1. Run some initialization program.?
2. Print tags ( is there a report, by bin, instead?). We will have
15,000 bins to count.
3. Counters put count on tag ( or report).
4. In some "count input" screen we have to key in each Part# and the
count.
5. Run Variance report, chase, Change count ( or add another?)
6. Run Post program which will change the QOH by Bin. Delete any with no
entry.
Is there a report you can run first to se total ads and deletes
DOLLAR value.
7. Is there a report for auditors of pluses and minuses by Part#\Bin
Questions:
2. Has anyione created a report instead of indivudual tags?
3. For count input, has anyone created an Updateable BAQ - lists in same
order as Count report?
What is file name of the PI count records? Can link to PartBin
file to get HI\LO field ( UDF)
4. Any Good White Papers or embedded Documentation?
Sun went live on 11/29/10
on Epicor 9, 9.05.601B SQL-Unidata
Sun was previously on M2K (Manage-2000) 7.0 SP 5 (Informix)
len.hartka@...
<blocked::blocked::mailto:len.hartka@...>
Leonard C. Hartka, IT Director\ERP Manager
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@...
www.Sunautomation.com <blocked::blocked::http://www.sunautomation.com/>
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Len,
We're gearing up for our first full physical in E9 on Monday. Although I haven't done a real one yet, I've simulated it in our test environment several times. Here are my notes:
> Questions:
> Flow:
Yes. Unlike in Vantage 8, there is an Initialize Physical Inventory program under Inventory Management > General Operations. It's pretty basic, all it does is begin the process, and the Count Cycle Maintenance program is where all the work is done. As a caveat, the date you click Start Count (under Actions menu in Count Cycle Maintenance) is the date your inventory will be recorded.
The tags print out in alphabetical order by bin. There is no option for any other sort.
Counters put count on tag, just as in Vantage
> count.
Count Tag Entry is the same as in Vantage 8.
Again, same as in Vantage 8.
> with no entry. Is there a report you can run first to se total ads
> and deletes DOLLAR value.
The variance report shows both qty and dollar value, again same as in Vantage 8.
I haven't found one.
> Questions:
I modified the tags, and you can print them out on sheets instead of individual tags.
> same order as Count report? What is file name of the PI count
> records? Can link to PartBin file to get HI\LO field ( UDF)
We're on 9.04 and don't have updateable BAQs. Counts are stored in the CCTag table, but I believe that once the count is posted that table is cleared (not sure though).
Embedded help is adequate but not stellar, and the process is just different enough from Vantage that you need to be careful. I haven't looked for any white papers or other docs.
Hope this helps!
Ernie Lowell
Diba Industries
