PID consuming CPU but cant be found
Now I would add each one back, one at a time until you find the one that sets off the PIDs.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Sent: Thursday, May 12, 2011 12:19 PM
Subject: Re: [Vantage] PID consuming CPU but cant be found
Ive killed all three now and the system seems fine.
Do you know how to use NET STOP to stop the AdminService for OpenEdge?
From: Blake Clemens <blake.clemens@... <mailto:blake.clemens%40d-m-c.com> >
Sent: Thu, 12 May, 2011 16:39:45
Subject: RE: [Vantage] PID consuming CPU but cant be found
Its definitely a strange one. Come in on a Saturday and restart your server.
Then monitor the PIDs. This way you can eliminate that it’s a user. If the PIDs
still show up then disable all of your schedules and restart your appservers. If
your schedules are not running and the PIDs are still showing up while there are
no users in the system then I am stumped. I would at that point check your
appserver and database settings. Did you kill the PID and see what happens?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of
Chris Thompson
Sent: Thursday, May 12, 2011 11:24 AM
We are on 9.04.505c.
They are all running and completing correctly (according to History Tasks).
Its strange - Epicor are baffled too.
From: Blake Clemens <blake.clemens@... <mailto:blake.clemens%40d-m-c.com> <mailto:blake.clemens%40d-m-c.com>
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Sent: Thu, 12 May, 2011 13:59:35
Try stopping all three. What version of Vantage are you running?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf
Of
Chris Thompson
Sent: Thursday, May 12, 2011 3:29 AM
We have three custom ones running.
Sent: Wed, 11 May, 2011 16:42:08
How many custom schedules do you have running?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of
Chris Thompson
Sent: Wednesday, May 11, 2011 11:39 AM
Yeh its still diabled.
Sent: Wed, 11 May, 2011 16:00:47
Nope. Go back into your System Agent Maintenance and see if the schedule is
still disabled.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of
Chris Thompson
Sent: Wednesday, May 11, 2011 11:00 AM
Yes. They are disabled now. Then stopped and started the T & P Apps.
Did I have to stop the T & P apps before disabling?
Sent: Wed, 11 May, 2011 15:55:31
So you've disabled the schedule in System Agent and then restarted Task &
Process Appserver?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of
Chris Thompson
Sent: Wednesday, May 11, 2011 10:44 AM
Hi
ive just followed your instructions and the tasks are still running.
Any ideas?
Sent: Wed, 11 May, 2011 14:49:24
Go into the System Agent Maintenance--Schedules tab and uncheck the "enable"
check box. Now restart your Process & Task agents in your Progress Explorer
tool. You will find that the schedule you unchecked in the System Agent
Maintenance is no longer running in your System Monitor.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of
Chris Thompson
Sent: Wednesday, May 11, 2011 9:36 AM
Stop them from System Monitor?
Sent: Wed, 11 May, 2011 13:43:38
No, just stop the schedules you created from running. Unless they are something
your company can't live without.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of
Chris Thompson
Sent: Wednesday, May 11, 2011 8:43 AM
Disable it in system agent?
Sent: Wed, 11 May, 2011 13:33:02
Either way, disable the schedule and see if that eliminates your
problem.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Chris Thompson
Sent: Wednesday, May 11, 2011 8:32 AM
We do have schedules, but I cant see how you can configure them wrong.
Or do you mean the item attached to them is configured wrong?
From: Waffqle <waffqle@... <mailto:waffqle%40gmail.com> <mailto:waffqle%40gmail.com>
<mailto:waffqle%40gmail.com> >
Sent: Wed, 11 May, 2011 13:24:08
Do you have any custom schedules attached to the system agent? If these
are
configured incorrectly, they can cause a situation almost exactly like
you
are describing.
On Wed, May 11, 2011 at 8:07 AM, Blake Clemens <blake.clemens@... <mailto:blake.clemens%40d-m-c.com>
<mailto:blake.clemens%40d-m-c.com> >wrote:
> Do you have Cyrstal Reports? Is there someone in your office that
creates
> custom reports?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Chris Thompson
> Sent: Wednesday, May 11, 2011 4:01 AM
> Hi
> By ODBC do you mean connected directly to the DB?
> All our reports are Epicor reports or custom BAQ reports. We dont
actually
> connect via ODBC (unless the way that Epicor does reports is classed
as
> ODBC).
> It is logical what you say but I dont think it applies to us.
> Is there any way of finding out if any reports are ODBC?
> From: DD <ddavis4569@... <mailto:ddavis4569%40yahoo.com> <mailto:ddavis4569%40yahoo.com>
<mailto:ddavis4569%40yahoo.com> >
> To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> " <
<mailto:vantage%40yahoogroups.com> >
> Sent: Tue, 10 May, 2011 18:10:47
> That could be a bad crystal report using odbc. The user gets tired of
> waiting
> and closes the report screen and logs off. The process hangs until the
> server is
> restarted or it may clear days later.
> It seems that 13% is what is used for each one that we have seen. I
have
> had the
> users do the same report over and over and each time it takes 13%.
> We never found out why - just the Crystal Report was launched with the
> wrong
> parameters and never finishes running.
> From: Chris Thompson <chriselectrix@... <mailto:chriselectrix%40ymail.com>
<mailto:chriselectrix%40ymail.com> <mailto:
> chriselectrix%40ymail.com> >
> Sent: Tuesday, May 10, 2011 8:59 AM
> Subject: [Vantage] PID consuming CPU but cant be found
> Hi
> I have a PID that is consuming 13% CPU but I have checked all of the
app
> servers
> and I can't see it.
> What else could it be?
> It says _proapsv.exe.
> Thanks.
have
and
http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/>
Hi
I have a PID that is consuming 13% CPU but I have checked all of the app servers
and I can't see it.
Thanks.
It could be one of the processes being managed by the TaskAgent (like
MRP) or ProcessServer (like MultiCompany).
ProcessExplorer
(http://technet.microsoft.com/en-us/sysinternals/bb896653) would help
you identify it if you really wanted to dig into it.
-bws
Of Chris Thompson
Sent: Tuesday, May 10, 2011 9:59 AM
Hi
servers
and I can't see it.
Thanks.
We have no active or scheduled tasks running according to system monitor.
Nobody is doing anything that they dont normally do.
Sent: Tue, 10 May, 2011 15:04:57
Â
ProcessExplorer
-bws
Of Chris Thompson
Hi
servers
and I can't see it.
Thanks.
You could try stopping and restarting the taskagent and processerver appservers and see if it gets killed.
Sent: Tuesday, May 10, 2011 10:14 AM
Â
ProcessExplorer
-bws
Of Chris Thompson
Hi
servers
and I can't see it.
Thanks.
Still no luck.
its been running since we last restarted the Apps (10pm last night).
Â
Sent: Tue, 10 May, 2011 15:24:11
Â
Chris Thompson
Â
ProcessExplorer
-bws
Of Chris Thompson
Hi
servers
and I can't see it.
Thanks.
It could be an orphaned/zombie appserver. If its really freaking you out you could just kill it and see what happens. ;-)
-bws
Sent: Tuesday, May 10, 2011 10:49 AM
Still no luck.
Â
Â
Chris Thompson
Â
ProcessExplorer
-bws
Of Chris Thompson
Hi
servers
and I can't see it.
Thanks.
Kill the PID with the Task Manager and see what happens. Go into your Vantage Admin Console and see if there are any old sign-ons still signed-in to Vantage.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Still no luck.
From: Brian W. Spolarich <bspolarich@... <mailto:bspolarich%40advancedphotonix.com> >
Chris Thompson
ProcessExplorer
-bws
Of Chris Thompson
Hi
servers
and I can't see it.
Thanks.
That could be a bad crystal report using odbc. The user gets tired of waiting and closes the report screen and logs off. The process hangs until the server is restarted or it may clear days later.
It seems that 13% is what is used for each one that we have seen. I have had the users do the same report over and over and each time it takes 13%.Â
We never found out why - just the Crystal Report was launched with the wrong parameters and never finishes running.
Â
Hi
and I can't see it.
Thanks.
I left the PID running last night and came in this morning to find two of them
running. Both exactly the same CPU use (12-13% - when one flicks to 12% the
other does at the same time).
Im wondering if this is linked to our weekly slow downs.
If we have 4 of these by Friday, that's 52% CPU usage drop.
We restarted our server on Sunday (Epicor's recommendation) because we were
having a complete slow down every 7-10 working days. When we get a slow down,
stopping the apps and db doesnt work. We have to restart the server.
If we restart the server on a Sunday and get one of these PIDs stuck at 12-13%
every working day (which is what appears to be happening), by the time we get to
the 7th/8th day, our CPU on the server is maxed out which is why we get a slow
down and a crash.
Then we restart the server and everything is ok for another 7-10 days.
I dont know if there is any logic in what I am saying, but the numbers certainly
seem to add up.
Question is, dare I kill these PIDs or am I going to mess up the whole system?!
Sent: Tue, 10 May, 2011 15:54:13
Â
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Chris Thompson
Still no luck.
Of
Chris Thompson
ProcessExplorer
-bws
Of Chris Thompson
Hi
servers
and I can't see it.
Thanks.
Hi
All our reports are Epicor reports or custom BAQ reports. We dont actually
connect via ODBC (unless the way that Epicor does reports is classed as ODBC).
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Â
Â
Hi
and I can't see it.
Thanks.
You won't mess up the system… just possibly crash it. I've done that already. We had a similar problem as what you are describing. I killed what I thought was a rogue PID and it stopped our database and kicked everyone out of the system.
You may have said this already but what version of Vantage are you running?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Sent: Wednesday, May 11, 2011 3:55 AM
down and a crash.
seem to add up.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Chris Thompson
Still no luck.
Of
Chris Thompson
ProcessExplorer
-bws
Of Chris Thompson
Hi
servers
and I can't see it.
Thanks.
Do you have Cyrstal Reports? Is there someone in your office that creates custom reports?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Hi
From: DD <ddavis4569@... <mailto:ddavis4569%40yahoo.com> >
To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> " <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
From: Chris Thompson <chriselectrix@... <mailto:chriselectrix%40ymail.com> >
Hi
and I can't see it.
Thanks.
Do you have any custom schedules attached to the system agent? If these are
configured incorrectly, they can cause a situation almost exactly like you
are describing.
> custom reports?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of Chris Thompson
> Hi
> ODBC).
> waiting
> server is
> had the
> wrong
> Hi
> servers
> and I can't see it.
> Thanks.
I am the only one who creates custom reports, but I never connect odbc I always
just connect to xml data from Epicor.
I might cancel them tonight and see what happens.
Sent: Wed, 11 May, 2011 13:07:09
Â
reports?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Chris Thompson
Hi
Hi
and I can't see it.
Thanks.
are describing.
> custom reports?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of Chris Thompson
> Hi
> ODBC).
> waiting
> server is
> had the
> wrong
> Hi
> servers
> and I can't see it.
> Thanks.
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
http://groups.yahoo.com/group/vantage/files/.%c2%a0
problem.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Chris Thompson
From: Waffqle <waffqle@... <mailto:waffqle%40gmail.com> >
are
you
are describing.
creates
> custom reports?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Chris Thompson
> Hi
actually
as
> ODBC).
> waiting
> server is
have
> had the
> wrong
> Hi
app
> servers
> and I can't see it.
> Thanks.
have
and
Â
problem.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Chris Thompson
are
you
are describing.
creates
> custom reports?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Chris Thompson
> Hi
actually
as
> ODBC).
> waiting
> server is
have
> had the
> wrong
> Hi
app
> servers
> and I can't see it.
> Thanks.
have
and
No, just stop the schedules you created from running. Unless they are something your company can't live without.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
problem.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Chris Thompson
From: Waffqle <waffqle@... <mailto:waffqle%40gmail.com> <mailto:waffqle%40gmail.com> >
are
you
are describing.
creates
> custom reports?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Chris Thompson
> Hi
actually
as
> ODBC).
> waiting
> server is
have
> had the
> wrong
> Hi
app
> servers
> and I can't see it.
> Thanks.
have
and
I forget the exact issue as it's been a LONG time since we ran into it. But
as best I can recall, there was an option in the schedule that was labeled
pretty unintuitively and activating it would cause the tasks to latch onto a
new appserver everytime they ran without releasing the previous one.
I know that's vague as as hell, but it's been a while since we dealt with
that. I can't find any emails or anything with the exact details.
If you want a faster way to test if this is the issue, increase the
frequency of your schedule. If you push it way up and your system bogs down
faster... tada!
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of Chris Thompson
> problem.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of Chris Thompson
> are
> you
> are describing.
> On Wed, May 11, 2011 at 8:07 AM, Blake Clemens <blake.clemens@...<mailto:
> creates
> > custom reports?
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
> Behalf
> > Of Chris Thompson
> > Hi
> actually
> as
> > ODBC).
> > waiting
> > server is
> have
> > had the
> > wrong
> > Hi
> app
> > servers
> > and I can't see it.
> > Thanks.
> have
> and
