Hello,
Not sure if anyone still needs help with this but we had this
problem show up over the weekend. Going into license maintenance and
deleting the one that was "all zeros" (which wasn't there before, it
got added during a server crash I believe) fixed it right away. Felt
silly after realizing it's such a simple fix.
Hope this helps someone,
Z
Z
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> Babette,
> By the sounds, you are on 6.1. Are you launching PlantFloor 6.1?
If so,
> are you launching PlantFloor 6.1 for your live database?
> I suspect you are launching Training or Test PlantFloor. If I am
correct,
> all you need to do is launch a full license of the same database
(training
> or test) and log in as a security manager. It will ask you to run the
> mandatory conversions and when done you can log back out and run
PlantFloor.
> (This is simply the first time you are logging into this DB).
> In answer to your question, as of 6.1 PlantFloor is the only way I
am aware
> of to utilize a DataCollection License. To utilize the Live DB of
course
> you will need to create and use an icon for the live DB, but I
assume you
> were attempting to test first anyway and that was the reason for the
trouble
> in the first place.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf Of
> Babette Welch
> Sent: Wednesday, November 15, 2006 3:41 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Plant-Floor error
> We are looking to set up a few workstations to use the DATA COLLECTION
> licenses we have.
> Up till now every station logs into a full license of Vantage
> 6.1/Progress.
> Admittedly we do not run PLANT-FLOOR yet now we need it.
> When I try to start PLANT-FLOOR I get the following error.
> Does anyone know how to fix this?
> Is Plant-Floor the best way to use a Data-collection license for
> time-clock information only?
> Thanks
> BW
> ERROR:
> "Database conversion programs need to be run. Cannot use the Shop
Floor
> programs before running the conversions from regular menu."
> Babette Welch
> IT Director
> Argonics, Inc.
> 1110 Wright Street
> Marquette MI 49855
> 906.226.9747 ext 235
