Please help..someone with crystal problem
Mark,
Not really a magic fix, but perhaps another way to handle the problem...
Could you set up the Misc. charges as a subreport? I suggest this for two reasons. For one, the last Vantage Sales Order I did for a client worked this way...I can only assume there is a reason I did it like that. Secondly, Crystal has a tendency to return null results when it is working with null data - even if you accomodate for that in your formula.
i.e.
If Not(IsNull({SomeField}) Then
{SomeField}
Else
0
...and the formula returns a blank. I've had mild success with the 'Convert NULL to default' option under File, Options but it does not ALWAYS fix my problem.
Warm Regards,
Adam Ellis
Senior Consultant - SaberLogic, LLC
Ph: (330) 335-6442
Mobile: (330) 697-3883
Mark Howard wrote:
>Let me sta r t from the beginning
>I'm on Vantage 5.10.125 and using Crystal 8.0.1.0 and am having problem with
>Quotes, Another user suggested I download a dbexdrvrwin_en.zip file but it
>didn't help after I ran it.
>My problem is when a salesperson adds a miscellaneous charge the line price
>disappears off the Quote, it will show the comments for miscellaneous charge
>like " Freight - $150.00".
>On the footer of my report I have a Subtotal and the a GST line and then a
>Grandtotal in the report footer
>Subtotal = Sum ({@totalline})
>GST = {@grandtotal}*.1
>Grandtotal = {@gst}+{@grandtotal}
>I can add the miscellaneous charge to the subtotal by doing = Sum
>({@totalline}) + Sum ({LineMisc.MISCAMT})
>But can't seem to the miscellanous change to a line in the group header I
>tried
>(ToNumber ({quoteqty.QUANTITY}) * ToNumber ({@UnitPrice})) +
>{LineMisc.MISCAMT} but when I do this I get nothing and also the subtotals
>disappear to.
>I'm hoping this makes sence and someone can help me out with a formula or a
>copy of a quote that has Line total with miscellous charge added to it.
>Mark Howard
>Financial Controller
>Jaws Buckets & Attachments
>This email, together with any attachments, is intended for the named
>recipient(s) only and may contain privileged and confidential information.
>No information within this email can be forwarded via email or verbally
>without the consent of the sender.
>If not an intended recipient of this email, you must not copy, distribute or
>rely upon it and any form of disclosure, modification, distribution and/or
>publication of this email is prohibited.
>Unless stated otherwise, this email represents only the views of the sender
>and not the views of Jaws Buckets & Attachments.
>[Non-text portions of this message have been removed]
>Yahoo! Groups Sponsor
>ADVERTISEMENT
><http://rd.yahoo.com/M=237459.2482214.3917349.2240799/D=egroupweb/S=17050071
>83:HM/A=1267611/R=0/*http://ad.doubleclick.net/jump/N2524.Yahoo/B1071650;sz=
>300x250;ord=1037149548998998?>
><http://us.adserver.yahoo.com/l?M=237459.2482214.3917349.2240799/D=egroupmai
>l/S=:HM/A=1267611/rand=408686177>
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
>already linked your email address to a yahoo id to enable access. )
>(1) To access the Files Section of our Yahoo!Group for Report Builder and
>Crystal Reports and other 'goodies', please goto:
>http://groups.yahoo.com/group/vantage/files/.
><http://groups.yahoo.com/group/vantage/files/.>
>(2) To search through old msg's goto:
>http://groups.yahoo.com/group/vantage/messages
><http://groups.yahoo.com/group/vantage/messages>
>(3) To view links to Vendors that provide Vantage services goto:
>http://groups.yahoo.com/group/vantage/links
><http://groups.yahoo.com/group/vantage/links>
>Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
><http://docs.yahoo.com/info/terms/> .
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
>(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
>(2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
>(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Let me stat from the beginning
tried
disappear to.
Mark Howard
tried
disappear to.
Mark Howard
ADVERTISEMENT
