Please HELP with RB question someone!
Mark,
The proper way to say "Not Equal to" in a formula is <>.
HTH,
Brian Stenglein
--- In vantage@y..., Mark Howard <mhoward@j...> wrote:
> I am have a real problem with a part of a formula, I have product
group
> ranges and different ranges belong to different production areas.
I have
> some quirky product that fall within a particular product group but
are
> really part of a different area. The only way I can flag them is in
the Part
> master file use one of the Character field and type something like
BH......
> My problem is when I add in my formula to excluded a particular
item that is
> in that group but has an BH in the user field I get a syntax error
you can
> see below the part of the formula that is causing me a problem...
> I need the formula to look at the particular range of product code
and if it
> fall within these codes BUT has a BH in the user field to exclude
it from
> the group..... I need a function Part.UserChar3 Not = "BH" but this
doesn't
> work any other way of doing a Not = to??
> iIf ((Description>="sp01000"and Description<="sp01099") or
> (Description>="sp01300"and Description<="sp01699") and
(Part.UserChar3 not =
> 'BH' ) , "Ecavator SP01000-SP01099 SP01300-SP01699")
> PG1
(Part.UserChar3 Not
> = "BH ") , "Ecavator SP01000-SP01099 SP01300-SP01699",iif
> ((Description>="sp01100"and description<="sp01199") or (description
> >="sp08100"and description<="sp08199") , "Quick Hitch SP01100-
SP01199
> SP08100-SP08199", "" ))
> PG2
> iIf ((Description>="sp07400"and Description<="sp07799")or
> (Description>="sp08000"and Description<="sp08099")or
> (description>="sp08200"and description<="sp08599") or
(Part.UserChar3 =
> "BH"), "Backhoe SP07400-SP07799 SP08000-SP08099 SP08200-
SP08599",iif
> (Description>="sp02000"and description<="sp02099" , "Long Reach
> SP02000-SP02099", iif(Description>="sp02100"and
description<="sp02299" ,
> "Ext. Boom SP02100-SP02299 ", "")))
> Mark Howard
> Financial Controller
> Jaws Buckets & Attachments
> This email, together with any attachments, is intended for the named
> recipient(s) only and may contain privileged and confidential
information.
> No information within this email can be forwarded via email or
verbally
> without the consent of the sender.
> If not an intended recipient of this email, you must not copy,
distribute or
> rely upon it and any form of disclosure, modification, distribution
and/or
> publication of this email is prohibited.
> Unless stated otherwise, this email represents only the views of
the sender
> and not the views of Jaws Buckets & Attachments.
I am have a real problem with a part of a formula, I have product group
ranges and different ranges belong to different production areas. I have
some quirky product that fall within a particular product group but are
really part of a different area. The only way I can flag them is in the Part
master file use one of the Character field and type something like BH......
My problem is when I add in my formula to excluded a particular item that is
in that group but has an BH in the user field I get a syntax error you can
I need the formula to look at the particular range of product code and if it
fall within these codes BUT has a BH in the user field to exclude it from
the group..... I need a function Part.UserChar3 Not = "BH" but this doesn't
(Description>="sp01300"and Description<="sp01699") and (Part.UserChar3 not =
PG1
(Description>="sp01300"and Description<="sp01699") and (Part.UserChar3 Not
>="sp08100"and description<="sp08199") , "Quick Hitch SP01100-SP01199
PG2
(description>="sp08200"and description<="sp08599") or (Part.UserChar3 =
"BH"), "Backhoe SP07400-SP07799 SP08000-SP08099 SP08200-SP08599",iif
SP02000-SP02099", iif(Description>="sp02100"and description<="sp02299" ,
Mark Howard
recipient(s) only and may contain privileged and confidential information.
No information within this email can be forwarded via email or verbally
If not an intended recipient of this email, you must not copy, distribute or
rely upon it and any form of disclosure, modification, distribution and/or
Unless stated otherwise, this email represents only the views of the sender
Mark -
You may want to double check how you are grouping your conditional
criteria.
Please make sure of what you are comparing in your conditional
criteria. Each of these equations are testing different criteria based
on the location of the parenthesis (). If it helps, remember the
mathematical order of operations for rule guidelines.
if (A or B and C) then D
If ( (A or B) and C) then D
if (A of (B and C) ) then D
kind of like:
(2 + 3) * 5 = 25
2 + (3 * 5) = 30
This sounds like the solution to what you are describing as the error.
Hope This Helps,
Misha 1, Ltd.
Calvin Dekker
www.misha1.net
Sent: Wednesday, November 27, 2002 5:29 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Please HELP with RB question someone!!!!!!!
Part
BH......
is
it
doesn't
PG1
Not
PG2
Mark Howard
or
sender
Yahoo! Groups Sponsor
ADVERTISEMENT
