Hi,
Steps to duplicate this issue.
1. Release a Job with one Non-stock purchase part.
2. Issue a PO to buy the non-stock purchase part to JOB
3. Reduce your job qty.
Now your non-stock purchase part required qty also reduced based on job qty.
You should able to see the PO change suggestion to reduce the existing PO
qty BUT it doesn't. The suggestion shows need to reduce but the QTY is
always "ZERO" in timephase report and shows the original PO qty in PO change
suggestion.
Epicor can able to duplicate this issue and hope that this will get fixed in
next patch 5.10126.
Regards,
Ellappan.
suggestion.
next patch 5.10126.
Regards,
Ellappan.
