PO Confirm Date
Is there a way to capture and display the date when the PO Confirm checkbox gets checked? We would like to be able to report on the cycle time from when a PO is sent to a supplier and when we receive their response.
Any input is appreciated.
Thank you.
I am going to guess you need to create a BPM to capture the time stamp on the check and then populate a field or a UD table. I am not sure if you can turn on Change Log for that field but that would check each time it is checked and unchecked.
