PO Cost Per Code
Hi Team,
I have a PO, someone has changed the cost per code to unitprice/100 and it affects the cost for this part. I can’t track which user to change it on changelog and the default setting for this part is already /1.
Is there any other way to check who changed it and to solve this issue i just need to perform cost adjustment for this part?
Please advice. Thanks
If you haven’t been tracking that already, the information you need is likely not there (the “Who did this”). However, if people are simply tabbing through and pressing buttons quickly, this is not unheard of as a result.
I assume you don’t actually need to know who did it to fix the cost though, right?
actually i wonder how come the PO Cost per code changed to E to C. By the way i already performed Cost adjustment for this case.
