PO Created for Job Material
Hi Karl,
Just wanted to know if you have had any problems today posting to the Yahoo Group? I keep getting 999 errors from Yahoo when I try to start a new Topic. Is anyone else getting this?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karl Dash
Sent: Thursday, August 23, 2012 8:54 AM
Subject: Re: [Vantage] Re: PO Created for Job Material
Thanks for all the responses. It seems that there were some twists and turns to the story. It would appear that the parts in question were originally created as non-stock and then jobs were created so consequently the parts were on the jobs as 'Purchase Direct'. A few POs were created and identified the purchase as 'Job Material'. So far, so good. Then the customer wanted us to lot track the parts, so they were changed to quantity bearing and the non-stock flag removed. But this didn't change the situation with the POs already created.
So, I created a couple of crystal quick and dirty programs to find all of the purchase direct parts on all jobs that were quantity bearing and unchecked that job material flag. Then I found all po releases for job material. I could delete each line at that point and re-create them. Problem solved.
Thanks again to all. -Karl
From: Manasa Reddy <manasa@... <mailto:manasa%40weldcoa.com> >
To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> " <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Sent: Wednesday, August 22, 2012 2:56 PM
Subject: RE: [Vantage] Re: PO Created for Job Material
You are right...it is the non-stock issue...just uncheck it on the part.
M. Manasa Reddy
mailto:manasa%40weldcoa.com <mailto:manasa%40weldcoa.com%3cmailto:mailto:manasa%40weldcoa.com> <mailto:mailto:manasa%40weldcoa.com>
630.806.2000 x1515
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Joshua Serwe
Sent: Wednesday, August 22, 2012 4:42 PM
To: mailto:vantage%40yahoogroups.com
Subject: [Vantage] Re: PO Created for Job Material
If non-stock is checked at the part level that might have something to do
with it.
Josh Serwe
Manager of Warehouse & Logistics
920.437.6400 Ext. 330
Safety
Professionalism
Effectiveness
Easy
Demand Results
<http://www.wisconsinconverting.com/>
How do I change a PO such that the line is for 'Inventory' and not 'Job Material'? I removed the 'Purchased Direct' from the offending part in Job Mgt and changed the part such that it is Qty Bearing. I've then tried to delete the line on the PO but it kicks out "Delete not allowed. Referenced by at least...". Any thoughts?
Â
Thanks, - Karl
with it.
Josh Serwe
Safety
Professionalism
Effectiveness
Easy
Demand Results
<http://www.wisconsinconverting.com>
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Serwe
with it.
Josh Serwe
Safety
Professionalism
Effectiveness
Easy
Demand Results
That won't necessarily help you change it on the PO for this one though if
it was already receipted to a job you may just need to return it off the
job into inventory.
Josh Serwe
Safety
Professionalism
Effectiveness
Easy
Demand Results
Â
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Â
M. Manasa Reddy
mailto:manasa%40weldcoa.com<mailto:mailto:manasa%40weldcoa.com>
630.806.2000 x1515
with it.
Josh Serwe
Safety
Professionalism
Effectiveness
Easy
Demand Results
