PO Detail - Mfg Name Issue
I’m in RDD trying to add the PODetail to GenRcpt because I want to capture the Mfg Name and Mfg Part ID on the receiving label. However, when I print the label it just bring up the number 0.
When I did a BAQ of PODetail, it is listing the “Mfg Num” as 0.
However, when I look at the PO line detail, the field is PODetail.MfgNum. So it is correct. Why is it not pulling the name and just a 0.
Any ideas why it’s pulling the value 0 and not the name? This is with Epicor 10.2.100.
I am not sure why it is zero, but I would guess that is an internal number Epicor assigns and you will then need to add the manufacturer’s table to link and convert that number to a name.
This is similar to customer number and vendor number assignments.
Brad
The field help is showing the value member (value written to database). The display member, as shown below, is what you see in the Combo and what you would want to have in the RDD
