PO Entry and PO Tracker customizations act differently from "Ope
Sean, thank you. Worked great.
--- In vantage@yahoogroups.com, "Sean McDaniel" <smcdaniel@...> wrote:
> If you do this while in developer mode it will come up with a prompt
> indicating the menu ID it is calling. Find that menu ID and you'll be
> all set.
> Of Sean McDaniel
> Sent: Monday, May 03, 2010 7:19 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] PO Entry and PO Tracker customizations act
> differently from "Open With"
> The open with option is actually opening a menu item. My guess is that
> not all the menu items have been set to the same customization.
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> Of sertyban
> Sent: Monday, May 03, 2010 6:37 PM
> Subject: [Vantage] PO Entry and PO Tracker customizations act
> I made similar customizations to PO Entry and PO Tracker and succesfully
> deployed these customizations throughout the system.
> Now, when getting from various programs to PO Entry using "Open With"
> function, users can see the added field. But when they try to do the
> same with PO Tracker, the field is not there.
> I see the same results from different program for all users.
> I did not find this happening with any other customizations (e.g., Order
> Entry and Order Tracker), just for PO Entry/Tracker only.
> Can you hint me what I could have done wrong?
> Thank you.
I made similar customizations to PO Entry and PO Tracker and succesfully deployed these customizations throughout the system.
Now, when getting from various programs to PO Entry using "Open With" function, users can see the added field. But when they try to do the same with PO Tracker, the field is not there.
I did not find this happening with any other customizations (e.g., Order Entry and Order Tracker), just for PO Entry/Tracker only.
Thank you.
Of sertyban
Thank you.
all set.
Of Sean McDaniel
Behalf
Of sertyban
Thank you.
