Did you ever find a way to join the customer to the memo?
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> ChangeLogs are the same way. Vantage stores the identifiers for the
> related record as a string in field Key1.
> However I've discovered that you can't write a BAQ that joins say
> Customer to ChangeLog or Memo because the customer identifier in
> Customer is CustNum, which is an integer, and Memo/ChangeLog.Key1 is a
> string. The BAQ will return null.
> Anyone know how to work around this type mismatch issue?
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@... ~ 734-864-5618 ~
> www.advancedphotonix.com
> Of bpbuechler
> Sent: Monday, February 02, 2009 3:33 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: PO Entry Comment Field
> Have you considered using Memos instead?
> You can add memos to a variety of records in Vantage even after the
> record is closed.
> Depending upon your use of this information, then you can write a
> baq/dashboard/crystal report and collect the memo contents. Just
> know that Memos are a table on their own, so you do have to specify
> the Related to File and Key1 to find the memo attached to the
> specific record.
> Thanks
> Patty Buechler
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
> Drecchio" <vic.drecchio@>
> wrote:
> > Hey gang, anybody have any ideas?
> > I need to create a comments field on PO Entry. Now, I know there's
> > already a tab for this on PO Entry Header.
> > That field will be fine.
> > My challenge is I need this field to be enabled and updateable no
> matter
> > the status of the PO. Once the PO has been Closed, the Vantage
> business
> > logic locks all fields down.
> > Has anyone been successful in defeating the Vantage business logic
> in
> > this fashion?
> > Thank you very much!
> > Vic
