PO Issue
I have a PO showing up in PO report on the PO tracker but not showing in the Dashboard. Any idea what might cause this??
By “dashboard”, I’m assuming you mean the buyer workbench or the new/change PO suggestion dashboards. Look up which buyer the PO is assigned to in PO tracker, then make sure the person(s) not able to see the PO are authorized users for that buyer.
Make sure you have a system default buyer too. I recommend having a true individual be the system default over a made up buyer people are supposed to monitor. Much more reliable to get part / part class setup issues fixed if that individual doesn’t want to keep getting new suggestions for that part. Also less likely to miss getting a PO out if people forgot to monitor that made up buyer.
