Knowing our vendors do this as well....I would love a 3rd field of
this sort in the sales order (and job info). I want to use the Need
by date as the date I am promising based on current lead times, the
shipping date as the date it would need to ship by to be delivered
by need by....and then a 3rd date field as Customer Request Date -
so if they are requesting ealier than promised - production tries to
reach that date if possible. I don't want to modify the Need By
date to when they request due to 'late shipments' if not met.
Anyone have any ideas here????
>do....
> I couldn't agree more with this process. It is exactly what we
>no
> "Promise Date is purely for vendor performance measurement. It has
> impact on planning whatsoever.confirmed
> Your Promise Dates should reflect the best date your vendor
> they COULD do (and, on initial PO creation, should be the same asthe
> Due Date).planning
> As time passes and you get updates from the vendor that the date is
> either improving or slipping, re-adjust your Due Dates so the
> system (and your people) are working with accurate info.based
> If you re-request an changed date, the Promise Date can be changed
> on the vendor's new (re)Promise commitment.accurate
> Following this paradigm gives your planning system & people
> info - and still leaves you with the ability to measure vendor on-time
> performance (to Promise Date).
> Rob Brown"
> -Ben Belzer
