PO received - wrong vendor
If you are using Vantage 8.00 then you will also need to delete out the PO lines I found out before you can change the supplier ID to the correct vendor and re-enter the PO lines before receiving correctly.
Rita
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
We received in a PO with the wrong vendor in February and now want to reverse the transaction so that we can pay the correct vendor for the goods. I know several options but wanted to see what others are doing when this happens
Never miss a thing. Make Yahoo your homepage.
If the item did not go through inspection, we un-receive the PO Receipt,
change the PO, then re-receive. Make sure to use the correct date on the
un-receive and re-receive transactions.
_____
Mark Wagner
Sent: Friday, March 28, 2008 9:33 AM
To: Vantage User Group
Subject: [Vantage] PO received - wrong vendor
happens
