PO Suggestion - Days of Supply
<!-- #ygrps-yiv-493353833 _filtered #ygrps-yiv-493353833 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-493353833 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-493353833 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-493353833 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-493353833 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-493353833 #ygrps-yiv-493353833 p.ygrps-yiv-493353833MsoNormal, #ygrps-yiv-493353833 li.ygrps-yiv-493353833MsoNormal, #ygrps-yiv-493353833 div.ygrps-yiv-493353833MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-493353833 a:link, #ygrps-yiv-493353833 span.ygrps-yiv-493353833MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-493353833 a:visited, #ygrps-yiv-493353833 span.ygrps-yiv-493353833MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-493353833 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-493353833 code
font-family:“Courier New”;}
#ygrps-yiv-493353833 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-493353833 tt
#ygrps-yiv-493353833 span.ygrps-yiv-493353833cat
#ygrps-yiv-493353833 span.ygrps-yiv-493353833ct
#ygrps-yiv-493353833 span.ygrps-yiv-493353833HTMLPreformattedChar
font-family:“Consolas”, “serif”;}
#ygrps-yiv-493353833 p.ygrps-yiv-493353833attach, #ygrps-yiv-493353833 li.ygrps-yiv-493353833attach, #ygrps-yiv-493353833 div.ygrps-yiv-493353833attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-493353833 p.ygrps-yiv-493353833bold, #ygrps-yiv-493353833 li.ygrps-yiv-493353833bold, #ygrps-yiv-493353833 div.ygrps-yiv-493353833bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-493353833 p.ygrps-yiv-493353833green, #ygrps-yiv-493353833 li.ygrps-yiv-493353833green, #ygrps-yiv-493353833 div.ygrps-yiv-493353833green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-493353833 p.ygrps-yiv-493353833replbq, #ygrps-yiv-493353833 li.ygrps-yiv-493353833replbq, #ygrps-yiv-493353833 div.ygrps-yiv-493353833replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-493353833 p.ygrps-yiv-493353833ad, #ygrps-yiv-493353833 li.ygrps-yiv-493353833ad, #ygrps-yiv-493353833 div.ygrps-yiv-493353833ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-493353833 p.ygrps-yiv-493353833underline, #ygrps-yiv-493353833 li.ygrps-yiv-493353833underline, #ygrps-yiv-493353833 div.ygrps-yiv-493353833underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-493353833 span.ygrps-yiv-493353833yshortcuts
#ygrps-yiv-493353833 p.ygrps-yiv-493353833ad1, #ygrps-yiv-493353833 li.ygrps-yiv-493353833ad1, #ygrps-yiv-493353833 div.ygrps-yiv-493353833ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-493353833 p.ygrps-yiv-493353833ad2, #ygrps-yiv-493353833 li.ygrps-yiv-493353833ad2, #ygrps-yiv-493353833 div.ygrps-yiv-493353833ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-493353833 p.ygrps-yiv-493353833underline1, #ygrps-yiv-493353833 li.ygrps-yiv-493353833underline1, #ygrps-yiv-493353833 div.ygrps-yiv-493353833underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-493353833 span.ygrps-yiv-493353833yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-493353833 span.ygrps-yiv-493353833yshortcuts2
font-weight:normal;}
#ygrps-yiv-493353833 span.ygrps-yiv-493353833EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-493353833 .ygrps-yiv-493353833MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-493353833 div.ygrps-yiv-493353833WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-493353833 ol
{margin-bottom:0in;}
#ygrps-yiv-493353833 ul
When generating new PO suggestions, does the system calculate using existing PO’s within the time frame set on the Days of Supply to calculate supply and demand if a new PO suggestion is generated?
For example, we have a 10 days of supply setting for a Part with an existing PO coming in on day number 5. However we have a shortage in demand that just came in on day 3, would a new PO suggestion be generated or not since the existing PO covers that shortage in demand already within that 10 days of supply? Our expectation is a new PO suggestion would be generated because a shortage in demand exists prior to the existing PO.
We have found in situations like this there will be no new suggestion. However, you should have a change suggestion to expedite the existing suggestion and/or increase the quantity. Depending on the situation, there also may be suggestions to cancel, postpone, or reduce the PO. You need to look in a Change PO Suggestions to find these.
Sue
---In vantage@yahoogroups.com, <cchang@...> wrote :
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 filtered #ygrps-yiv-536731519ygrps-yiv-249256146 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} #ygrps-yiv-536731519 filtered #ygrps-yiv-536731519ygrps-yiv-249256146 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} #ygrps-yiv-536731519 filtered #ygrps-yiv-536731519ygrps-yiv-249256146 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} #ygrps-yiv-536731519 filtered #ygrps-yiv-536731519ygrps-yiv-249256146 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-536731519 filtered #ygrps-yiv-536731519ygrps-yiv-249256146 {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146MsoNormal, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146MsoNormal, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman", "serif";} #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 a:link, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146MsoHyperlink { color:blue;text-decoration:underline;} #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 a:visited, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146MsoHyperlinkFollowed { color:purple;text-decoration:underline;} #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p {
margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 code
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 pre
margin:0in;margin-bottom:.0001pt;font-size:10.0pt;font-family:“Courier New”;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 tt
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146cat
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146ct
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146HTMLPreformattedChar
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146attach, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146attach, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146attach
margin-right:0in;margin-left:0in;font-size:9.0pt;font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146bold, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146bold, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146bold
margin-right:0in;margin-left:0in;font-size:10.0pt;font-family:“Arial”, “sans-serif”;font-weight:bold;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146green, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146green, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146green
margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;color:#628C2A;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146replbq, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146replbq, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146replbq
margin:3.0pt;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146ad, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146ad, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146ad
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146underline, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146underline, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146underline
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146yshortcuts
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146ad1, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146ad1, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146ad1
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146ad2, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146ad2, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146ad2
margin-right:0in;margin-bottom:7.5pt;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 p.ygrps-yiv-536731519ygrps-yiv-249256146underline1, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 li.ygrps-yiv-536731519ygrps-yiv-249256146underline1, #ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146underline1
margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;text-decoration:underline;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146yshortcuts1
font-family:“Verdana”, “sans-serif”;font-weight:bold;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146yshortcuts2
font-family:“Verdana”, “sans-serif”;font-weight:normal;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 span.ygrps-yiv-536731519ygrps-yiv-249256146EmailStyle36
font-family:“Calibri”, “sans-serif”;color:#1F497D;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 .ygrps-yiv-536731519ygrps-yiv-249256146MsoChpDefault
font-size:10.0pt;}
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 div.ygrps-yiv-536731519ygrps-yiv-249256146WordSection1
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 ol
#ygrps-yiv-536731519 #ygrps-yiv-536731519ygrps-yiv-249256146 ul
TimePhase and in change Sugg.
Do you keep logs of MRP.  I would look at one Part and see what it says.  You should see the suggestions in there are well.  I have seen where my users tell me MRP is creating excess jobs and no suggestions.  Ended up being other users would delete the suggestions.
What version you running?
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, June 17, 2016 8:31 AM
Subject: RE: [Vantage] PO Suggestion - Days of Supply
Does change suggestions show up in Time Phase also for these situations or only through the Change PO Suggestions screen?
Sent: Friday, June 17, 2016 10:28 AM
Subject: Re: [Vantage] PO Suggestion - Days of Supply
Sue
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
Hi,
What about the Planning Time Fence in the Part class, Plant section? the help says “Defines a time limit for changes within this part class. This value is the number of days from the current system date that demands requiring supply changes will not be considered by the system. All demands outside of this time limit, however, will be processed as normal.”
Sent: 20 June 2016 15:06
We are on 702a.  The MRP log is showing a shortage in demand but no new PO suggestions generated in the logs also.  I’m thinking this has something to do with the Days of Supply, where if supply and demand are fulfilled within the Days of Supply time horizon, no new PO suggestions will be generated even if the shortage in demand is before an existing PO.
Sent: Friday, June 17, 2016 5:16 PM
Miguel A. Santillan
Sue
Disclaimer
