PO Suggestion Demand for Purchases to Inventory
The PartDtl table is the actual underpinning for TimePhase, and the SourceFile field tells you where the demand originates (Indicates the record type that created this record. JH-JobHead, JA-JobAsmbl, JM-JobMtl, JO-JobOper, PO-PoRels, OR-OrderRels, FC-ForCast).
Ernie Lowell
Diba Industries
I have been asked to capture the reason PO Suggestions are created by MRP in an exclusive buy to inventory job shop.  The users are currently opening Time Phase with each PO Suggestion to determine where the suggestion came from, but since they are all buy to inventory the demand is never captured.
Any ideas?
John
I  run a routine like this on posugg.getrowsplant. I will send to you offline as it does a lot of other things.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mitchelljohn@...
Sent: Wednesday, December 11, 2013 1:57 PM
Subject: [Vantage] PO Suggestion Demand for Purchases to Inventory
Any ideas?
John
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Greg,
Awesome!  You can send it to jmitchell@...
John
Greg,
Didn't realize Yahoo cuts out email addresses.  So, jmitchell at kadantbc dot com.  Thanks,
John
