Thanks that worked
--- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@...> wrote:
> Is it possible that your organization has had several versions of the
> PO Form and that you are looking at an older version?
> To make sure that you are looking at the correct one:
> Go to System Management,
> Configuration Maintenance,
> Report Sytle.
> Find the PO Form.
> Then there will be a list of Styles.
> Look for the Style which is marked Type=Crystal and Default=Yes.
> Double-click on that Style.
> A new window will open which will show you the exact path and
> filename where the Crystal Report is located.
> Compare a sample hardcopy PO to the Crystal Report in the Design View
> to locate the field you want to change.
> --- In vantage@yahoogroups.com, "zuhaib" <zuhaib_akhtar@> wrote:
> > I am using vantage 6 and crystal report.I was looking this text on
> the
> > PO form but couldnt find it(Terms and conditions thing)
> > --- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@> wrote:
> > > What version of Vantage are you using?
> > > Is it a Crystal Report?
> > > Are you just saying that you need to modify the text that appears
> in
> > > one of the footers of the Crystal Report?
> > > > I have to change my terms and conditions code (example REV "A"
> > > > 11-2-2007) printed at the bottom of purchasing order.Can anyone
> help
> > > > me with this.
> > > > thank you
> > > > zuhaib
