PO to Invoice? Blank Title 58627
Yep, that was the magic table. All of the information we need is
there.
Thanks Jim! You really helped us out.
Bruce
--- In vantage@yahoogroups.com, "Jim Frice" <Jim.Frice@...> wrote:
> Why not use the APInvcDtl it has probably all the information you
need.
> It is a pretty easy report to put together in Report Builder. What
two
> tables due you really want? If you have already gone from Po to
Receipts
> using the PO number that is also available on the APInvcDtl table.
Or
> use the PackSlip from the Receipt table to the APInvcDtl table.
> Jim
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
> On Behalf Of brucewbrannan
> Sent: Monday, August 20, 2007 4:21 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] PO to Invoice?
> We have a project manager who needs to print POs to Invoices.
We
> can
> build the links from POs (stuff we're buying) to Receipts
(stuff
> we're
> receiving) and the Receipts does contain the Invoice numbers.
> But I
> can't seem to link the Invoice numbers from the Receipts
tables
> to the
> Invoice tables. Any suggestions or has anybody built this
report
> before? We are still on 6.1, Progress Db. If you go to the
> receipt
> tracker it clearly shows the PO, Receipt, and Invoice
> information all
> in one nice screen but we really need an export or report to
> compile
> this information together. Canned Vantage has no way of
> reporting this
> information.
> Thanks!
> Bruce Brannan
> Engineered Products Department
We have a project manager who needs to print POs to Invoices. We can
build the links from POs (stuff we're buying) to Receipts (stuff we're
receiving) and the Receipts does contain the Invoice numbers. But I
can't seem to link the Invoice numbers from the Receipts tables to the
Invoice tables. Any suggestions or has anybody built this report
before? We are still on 6.1, Progress Db. If you go to the receipt
tracker it clearly shows the PO, Receipt, and Invoice information all
in one nice screen but we really need an export or report to compile
this information together. Canned Vantage has no way of reporting this
information.
Thanks!
Bruce Brannan
Why not use the APInvcDtl it has probably all the information you need.
It is a pretty easy report to put together in Report Builder. What two
tables due you really want? If you have already gone from Po to Receipts
using the PO number that is also available on the APInvcDtl table. Or
Jim
can
we're
But I
to the
receipt
information all
compile
reporting this
information.
Thanks!
Bruce Brannan
