ditto
mthompson@...]
Sent: Wednesday, November 15, 2000 8:05 AM
To:
vantage@egroups.com
Subject: RE: [Vantage] PO variances
the difference is created from the inventory unit of measure
being different
than the purchase unit of measure. We inventory
tube in 21 ft. lengths but our supplier sells to us in lbs. A
tube has a
standard weight of say 250 lbs but due to production
variances that same length of tube could be 265 lbs and thus
your invoice
from your supplier will have a different total. This
should be viewed as a price variance for accounting purposes, as
your
inventory quantities are correct.
Jim.Frice@...]
Sent: Tuesday, November 14, 2000 5:25 PM
To:
vantage@egroups.com
If the vendor ships you 23 feet what is the quantity you are
receiving? It
should be 23 feet even if you ordered 20 feet. If the po is
coming across
with $140 from the receipt then your receiving quantity is what
is
incorrect.
> From: gilsonscreen@... [mailto:gilsonscreen@...]
> Sent: Tuesday, November 14, 2000 1:53 PM
> To: onelist
> Subject: [Vantage] PO variances
> Hello Vantage Users
> I would like to know how others are handling the following...
We
> buy steel bar priced by the foot. We issue a purchase order
to
> our vendor for a given amount of material (let's say 20 feet.)
> The vendor quotes us a price of $7.00 per foot and that is
> entered into the PO. The vendor ships us 23 feet (because bar
> usually comes in 17 - 24 foot random lengths) and that is what
we
> receive into inventory. The vendor's invoice says $161.00 (23
x
> 7) and our PO says $140.00. A variance of $21.00. Our
> accounting people want to know why there is a variance on the
PO.
> Are we missing something on this variance thing? Is there
some
> way to correct our procedure?
> thank you
> Mel
> We no longer allow attachments to files. To access/share
Report
> Files, please go to the following link:
> http://www.egroups.com/files/vantage/
> (Note: If this link does
> not work for you the first time you try it, go to
> www.egroups.com, login and be sure to save your password,
choose
> My Groups, choose Vantage, then choose Files. If you save the
> password, the link above will work the next time you try it.)
eGroups Sponsor
We no longer allow attachments to files. To access/share Report
Files,
(Note: If this link does not work for you the first time you
try it, go to
www.egroups.com, login and be sure to save your password, choose
My Groups,
choose Vantage, then choose Files. If you save the password,
the link above
-------------------------- eGroups Sponsor
try it, go to www.egroups.com, login and be sure to save your password,
choose My Groups, choose Vantage, then choose Files. If you save the
