PODetail Blank Title 56301
I don't think I can directly address the question, partly because I am too much of a novice at Progress routines but here is the code from a .p routine I use to populate fields on a VB Form from the "calling" screen. Perhaps there is something in it that will spark an idea. Note V: is mapped to the mfgsys61 folder.
-Todd C.
Description: This routine sets default value on VB Form fields for SubShipD
Define Variable POLineVar as Int.
Define Variable PORelVar as Int.
/* INCLUDE vbp/vb.i SO THAT VantageBasic FUNCTIONS ARE AVAILABLE. */
{V:\Vantage\vbp/vb.i}
POLineVar = getDecimalValue("POLine.scrvalue").
PORelVar = getDecimalValue("PORel.scrvalue").
if POLineVar = 0 then Do:
setDecimalValue("POLine.scrvalue":U,1.0).
End.
if PORelVar = 0 then Do:
setDecimalValue("PORel.scrvalue":U,1.0).
End.
RETURN.
/-----Original Message-----
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Sandy Morse
Sent: Friday, April 13, 2007 3:15 PM
Subject: [Vantage] PODetail
I am trying to add a VB form to the PO Line Maintenance Screen. The VB
Form is to capture the Manufacturer and Manufacturer's Part Number from
the Line Maintenance Screen. Is there a way to transfer either the part
number from the screen or the two fields I need onto the VB form. I
have two character fields set up on the Form and I have a Progress
procedure which is run on entry. However, the two fields still stay
blank when I test this. Help of any kind is appreciated!
Sandy Morse
BVR Technologies Company
815-874-2471 x112
The information in this message is proprietary and/or confidential and
is intended only for the use of the individual(s) named above. This
message should not be forwarded without permission from the author. If
this message is received in error or otherwise by someone other than the
addressee, please contact the author at the above number and return the
message or destroy it. In addition, the recipient of this data agrees to
abide by the United States Export Control of Technical Data and
Equipment under the International Traffic in Arms Regulations (ITAR) and
Export Administration Regulations (EAR). The recipient agrees to abide
by these laws and their regulations not only for export and re-export,
but for disclosure to non-U.S. citizens.
Sandy Morse
815-874-2471 x112
