Pop-up Blank Title 90042
One other thing I would add, sometimes I find comparing it to a blank field
("") doesn't always catch everything, particularly if you loaded some data
fields with a rogue method. Progress syntax uses the question mark for a
null field, so your syntax may look like:
IF IssueReturn.TranReference = "" OR
IssueReturn.TranReference = ?
Note, you don't put the question mark in parenthesis .
Kevin Simon
Brian W. Spolarich
Sent: Wednesday, May 05, 2010 4:19 PM
Subject: RE: [Vantage] Pop-up
Based on a trace, it looks like IssueReturn is the BO and
PerformMaterialMovement is the method.
<tracePacket>
<businessObject>Epicor.Mfg.BO.IssueReturn</businessObject>
<methodName>PerformMaterialMovement</methodName>
<returnType>void</returnType>
<localTime>5/5/2010 16:07:58:3663231 PM</localTime>
<executionTime>249.9936</executionTime>
<parameters>
<parameter name='plNegQtyAction' type='System.Boolean'
><![CDATA[False]]></parameter>
<parameter name='ds' type='Epicor.Mfg.BO.IssueReturnDataSet'
><IssueReturnDataSet
xmlns="http://www.epicor.com/Mfg/100/BO.IssueReturn/IssueReturn">
<IssueReturn>
<Company>OPTO</Company>
<TranDate>2010-05-05T00:00:00-04:00</TranDate>
<PartNum>004-11-41-211</PartNum>
<TranQty>10</TranQty>
<DimCode />
<LotNum />
<ReasonCode>AA002</ReasonCode>
<OrderNum>0</OrderNum>
I would make a pre-processing BPM on this method where the condition is:
the IssueReturn.TranReference field of the changed row is equal to the ""
value
and the action is to raise an exception.
Note that using the "Null" condition doesn't work. Otherwise, clean and
easy.
-brian
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
www.advancedphotonix.com
Behalf Of CarlH
Sent: Wednesday, May 05, 2010 3:57 PM
Subject: [Vantage] Pop-up
Any simple ideas how to get a pop-up if a user fails to fill in a field. We
want to remind users to fill out the remarks field in Misc Issue of
materials
Any simple ideas how to get a pop-up if a user fails to fill in a field. We want to remind users to fill out the remarks field in Misc Issue of materials
What version are you on? If you are in 8.03 you can create a BPM to trigger a pop up.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01CAEC6C.1E0B7190]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of CarlH
Use an Exception message in a BPM.
This will force them to fill in the field. An informational message won't
stop them.
Ross
CarlH
Sent: Wednesday, May 05, 2010 2:57 PM
materials
Based on a trace, it looks like IssueReturn is the BO and PerformMaterialMovement is the method.
<tracePacket>
<parameters>
<parameter name='plNegQtyAction' type='System.Boolean' ><![CDATA[False]]></parameter>
<parameter name='ds' type='Epicor.Mfg.BO.IssueReturnDataSet' ><IssueReturnDataSet xmlns="http://www.epicor.com/Mfg/100/BO.IssueReturn/IssueReturn">
<IssueReturn>
<DimCode />
<LotNum />
the IssueReturn.TranReference field of the changed row is equal to the "" value
Note that using the "Null" condition doesn't work. Otherwise, clean and easy.
-brian
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
