Populate UD field in UltraWinGrid
The winning code! Thanks for your help on this, Jose.
private static void grdPackOutList_InitializeRow(object sender, Infragistics.Win.UltraWinGrid.InitializeRowEventArgs args)
Epicor.Mfg.Core.Session epiSession = (Epicor.Mfg.Core.Session)CustShipForm.Session;
BOReader _boReader = new BOReader(epiSession.ConnectionPool);
DataSet ds = _boReader.GetRows("Part", "Part.PartNum='" + args.Row.Cells["PartNum"].Value.ToString() + "'", "CheckBox06");
if (ds.Tables[0].Rows.Count > 0)
args.Row.Cells["CheckBox06"].Value = ds.Tables[0].Rows[0]["CheckBox06"].ToString();
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> your episession should come from oTrans
> oTrans.Session you'll need to cast that to Epicor.Mfg.Core.Session.
> *Jose C Gomez*
> *Software Engineer*
> *checkout my new blog <http://www.usdoingstuff.com> *
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Wed, Feb 29, 2012 at 5:23 PM, altyrocks <alty_rocks@...> wrote:
> > OK, I think I'm getting close. I have the BOReader defined but now I'm
> > getting an error with the epiSession.
> > How should I define that?
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > It does only work for custom controls, draw a custom grid have it
> > generate
> > > then re-write it slightly for your control you are going to need to
> > use
> > > csm.GetNativeControlReference(GUID) to get the instance of the
> > control.
> > > _boReader is a library which allows you to query any Business Object.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Wed, Feb 29, 2012 at 12:43 PM, altyrocks alty_rocks@ wrote:
> > > > Ha ha, I love the automagically factor. Are you talking about the
> > Event
> > > > Wizard tab? It looks like that only works for custom controls and
> > not my
> > > > standard grid. Also, what is the _boreader? Thanks!
> > > > --- In vantage@yahoogroups.com, Jose Gomez jose@ wrote:
> > > > > Its a magical where clause LoL, you can ignore that line, in the
> > Event
> > > > > Selection screen you can pick your Grid and initialize to have it
> > > > generate
> > > > > the event for you.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > On Wed, Feb 29, 2012 at 12:08 PM, altyrocks alty_rocks@ wrote:
> > > > > > Thanks for the reply. I'm not fully understanding how to
> > implement
> > > > > > this. Is there a wizard that creates this initialize event in
> > > > Epicor?
> > > > > > If not, I'm assuming I call it in the InitializeCustomCode event
> > but
> > > > I'm
> > > > > > not sure what parameters I need to pass to the method.
> > > > > > Also, you create the whereClause and assign it a string value
> > but I
> > > > > > don't ever see it getting used anywhere.
> > > > > > > You need to populated on the Initialzie Row event of the grid.
> > > > > > > private static void grdMatLst_InitializeRow(object sender,
> > > > > > > Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e)
> > > > > > > String whereClause =
> > > > > > > "Part.PartNum='"+e.Row.Cells["PartNum"].Value.ToString()+"'";
> > > > > > > DataSet ds =
> > _boReader.GetRows("Part","Part.PartNum='"+e.Row.Cells["PartNum"].Value.T\
> > > > > > oString()+"'","Mtl-AnalysisCode");
> > > > > > > if(ds.Tables[0].Rows.Count>0)
> > e.Row.Cells["MatAnal"].Value=ds.Tables[0].Rows[0]["Mtl-AnalysisCode"].To\
> > > > > > String();
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
> > > > > > > On Tue, Feb 28, 2012 at 12:43 PM, altyrocks alty_rocks@ wrote:
> > > > > > > > Hello. I am trying to display the Part.CheckBox06 value on
> > the
> > > > > > PackOut tab
> > > > > > > > of the Customer Shipment Entry screen. I need it to show up
> > in
> > > > the
> > > > > > Details
> > > > > > > > grid at the bottom of the screen. I have successfully added
> > a
> > > > > > checkbox to
> > > > > > > > the grid using the following code:
> > > > > > > > private static void CustShipForm_Load(object sender,
> > EventArgs
> > > > args)
> > > > > > > > EpiUltraGrid grdPackOutList =
> > (EpiUltraGrid)csm.GetNativeControlReference("d9062e9e-321b-4f96-8883-c83\
> > > > > > c0889e0f8");
> > grdPackOutList.DisplayLayout.Bands[0].Columns.Add("CheckBox06",
> > > > "Do
> > > > > > Not
> > > > > > > > Freeze");
> > > > grdPackOutList.DisplayLayout.Bands[0].Columns["CheckBox06"].DataType
> > > > > > > > typeof(bool);
> > > > grdPackOutList.DisplayLayout.Bands[0].Columns["CheckBox06"].Style =
> > > > > > > > Infragistics.Win.UltraWinGrid.ColumnStyle.CheckBox;
> > grdPackOutList.DisplayLayout.Bands[0].Columns["CheckBox06"].CellActivati\
> > > > > > on
> > > > > > > > = Activation.Disabled;
> > > > > > > > but I'm not sure how to populate values in that checkbox.
> > Just
> > > > > > adding the
> > > > > > > > column doesn't sync it to the Part.CheckBox06.
> > > > > > > [Non-text portions of this message have been removed]
Hello. I am trying to display the Part.CheckBox06 value on the PackOut tab of the Customer Shipment Entry screen. I need it to show up in the Details grid at the bottom of the screen. I have successfully added a checkbox to the grid using the following code:
private static void CustShipForm_Load(object sender, EventArgs args)
EpiUltraGrid grdPackOutList = (EpiUltraGrid)csm.GetNativeControlReference("d9062e9e-321b-4f96-8883-c83c0889e0f8");
grdPackOutList.DisplayLayout.Bands[0].Columns.Add("CheckBox06", "Do Not Freeze");
grdPackOutList.DisplayLayout.Bands[0].Columns["CheckBox06"].DataType = typeof(bool);
grdPackOutList.DisplayLayout.Bands[0].Columns["CheckBox06"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.CheckBox;
grdPackOutList.DisplayLayout.Bands[0].Columns["CheckBox06"].CellActivation = Activation.Disabled;
but I'm not sure how to populate values in that checkbox. Just adding the column doesn't sync it to the Part.CheckBox06.
DataSet ds = _boReader.GetRows("Part","Part.PartNum='"+e.Row.Cells["PartNum"].Value.ToString()+"'","Mtl-AnalysisCode");
e.Row.Cells["MatAnal"].Value=ds.Tables[0].Rows[0]["Mtl-AnalysisCode"].ToString();
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Freeze");
> typeof(bool);
Thanks for the reply. I'm not fully understanding how to implement
this. Is there a wizard that creates this initialize event in Epicor?
If not, I'm assuming I call it in the InitializeCustomCode event but I'm
Also, you create the whereClause and assign it a string value but I
> DataSet ds =
String();
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
PackOut tab
Details
checkbox to
c0889e0f8");
Not
> > Freeze");
> > typeof(bool);
on
adding the
Its a magical where clause LoL, you can ignore that line, in the Event
Selection screen you can pick your Grid and initialize to have it generate
the event for you.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > DataSet ds =
> String();
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> PackOut tab
> Details
> checkbox to
> c0889e0f8");
> Not
> > > Freeze");
> > > typeof(bool);
> on
> adding the
Ha ha, I love the automagically factor. Are you talking about the Event
Wizard tab? It looks like that only works for custom controls and not my
generate
> the event for you.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
Epicor?
I'm
> > > DataSet ds =
> > String();
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > PackOut tab
the
> > Details
> > checkbox to
args)
> > c0889e0f8");
"Do
> > Not
> > > > Freeze");
> > > > typeof(bool);
> > on
> > adding the
It does only work for custom controls, draw a custom grid have it generate
then re-write it slightly for your control you are going to need to use
csm.GetNativeControlReference(GUID) to get the instance of the control.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> generate
> > the event for you.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> Epicor?
> I'm
> > > > DataSet ds =
> > > String();
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > PackOut tab
> the
> > > Details
> > > checkbox to
> args)
> > > c0889e0f8");
> "Do
> > > Not
> > > > > Freeze");
> > > > > typeof(bool);
> > > on
> > > adding the
generate
use
control.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
Event
not my
Event
> > generate
> > > the event for you.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
implement
> > Epicor?
but
> > I'm
but I
> > > > > DataSet ds =
> > > > String();
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
the
> > > > PackOut tab
in
> > the
> > > > Details
a
> > > > checkbox to
EventArgs
> > args)
> > > > c0889e0f8");
> > "Do
> > > > Not
> > > > > > Freeze");
> > > > > > typeof(bool);
> > > > on
Just
> > > > adding the
*Jose C Gomez*
*Software Engineer*
E: jose@...
> generate
> use
> control.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> Event
> not my
> Event
> > > generate
> > > > the event for you.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> implement
> > > Epicor?
> but
> > > I'm
> but I
> > > > > > DataSet ds =
> > > > > String();
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@
> the
> > > > > PackOut tab
> in
> > > the
> > > > > Details
> a
> > > > > checkbox to
> EventArgs
> > > args)
> > > > > c0889e0f8");
> > > "Do
> > > > > Not
> > > > > > > Freeze");
> > > > > > > typeof(bool);
> > > > > on
> Just
> > > > > adding the
Thanks for sharing, Naomi. I think your technique is what Jose has been alluding to.
When the UDCodes are bound to a particular DB table and field this seems like the way to go. My situation was a little different in that CallContextBPMData doesn't have extended properties.
For me, part of the problem in programming Epicor is that there are too many ways to do things. I strive to do it the "right" way. But when there are 3 combo boxes, each with 50ish properties, and multiple ways of populating them, It's like being in a restaurant with too many choices on the menu.
I use combo-box as an example but the same can be said for many areas of the system. Data vs. Method directives, "inline" code vs. "forward to", pre, post, base, or in-transaction hooks. It's awfully easy to "order" wrong!
No worries -- we soldier on.
- Chris
NOT INTENDED AS A SUBSTITUTE FOR A WRITING
NOTHING IN THIS E-MAIL, IN ANY E-MAIL THREAD OF WHICH IT MAY BE A PART, OR IN ANY ATTACHMENTS THERETO, SHALL CONSTITUTE A BINDING CONTRACT, OR ANY CONTRACTUAL OBLIGATION BY PNY, OR ANY INTENT TO ENTER INTO ANY BINDING OBLIGATIONS, NOTWITHSTANDING ANY ENACTMENT OF THE UNIFORM ELECTRONIC TRANSACTIONS ACT, THE FEDERAL E-SIGN ACT, OR ANY OTHER STATE OR FEDERAL LAW OF SIMILAR SUBSTANCE OR EFFECT. THIS EMAIL MESSAGE, ITS CONTENTS AND ATTACHMENTS ARE NOT INTENDED TO REPRESENT AN OFFER OR ACCEPTANCE OF AN OFFER TO ENTER INTO A CONTRACT. NOTHING IN THIS E-MAIL, IN ANY E-MAIL THREAD OF WHICH IT MAY BE A PART, OR IN ANY ATTACHMENTS THERETO SHALL ALTER THIS DISCLAIMER.
This e-mail message from PNY Technologies, Inc. is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
