Trying to set up a way to populate my field group (invoice line items). Currently the workflow will run a transactions datalink for positive value invoices, and will run a returns datalink for credit invoices, by way of some if/else logic. Customer wants BOTH to run now, because they often get invoices with both return and purchase lines.
Both datalinks are set up with the DataLink Field Group task
I can’t figure out how to get one DataLink to run, populate the field group, then get the other one to run and just add on the lines, rather than overwriting. I have tried experimenting with the Set Field Group Values task set to Append, but I think I must be missing something.
I believe you can do this with a Datalink task for the secondary datalink. Use a temp field to store the values and use a Set Field group with append to join those rows to the first field group rows.
What kind of datalinks are those? Are they built-in (part of an Automation product) or custom?
A weird behavior I did notice - the solution you mentioned works great - regular datalink just gave out multi-valued temp fields (my source had 3 rows), but if I invoked this task AFTER running the regular datalink field group, it would only pull 1 row.
But changing the order around worked, i just thought it was weird.
