This will need to be done as a pre-processing directive. Make the updates in
the temp tables and you should be ok.
On Mon, Nov 22, 2010 at 9:49 AM, nustepvantage <dpfiester@...> wrote:
> Hi All,
> I have a post-processing BPM using the SalesOrder.Update method that copies
> data to user defined fields in the OrderHed table when an order line is
> saved. The data copies over fine, but the fields appear blank. The user
> needs to click the refresh button in order to view the data and make changes
> to fields in the OrderHed table. If the refresh button is not clicked, then
> the user sees a dialog box, saying the record has been modified by another
> user and cannot be updated. Is there a way I can refresh the data in
> OrderHed so a user doesn't have to do the additional click? The situation
> has caused a couple of shipment errors. We are running Vantage 803.406A.
> Thanks,
> David Pfiester
> Systems Accountant
> NuStep, Inc.
> 734-769-3939 x150.
