I have begun exporting datasets from DMT using a PowerShell script. It appears to work but I’m not seeing the corresponding *.CompleteLog.txt file that should come with it. I can see that there are command line switches to turn these logs off but I’m not using those switches. Shouldn’t the log be in the same folder as the -Target by default?
If I had to guess the CompleteLog.txt is only for -Add, -Update or -Delete – Perhaps a BAQ Export doesnt contain it because the baq csv or xml would basically indicate its completion?
