Preferred way to make a field read only?
I second Extended Properties
Of Jose Gomez
Sent: Tuesday, January 18, 2011 11:59 AM
Subject: Re: [Vantage] Preferred way to make a field read only?
Extended Properties is the way to go I think.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
On Tue, Jan 18, 2011 at 12:34 PM, cooner_55421
<cooner_55421@...>wrote:
> Hi,
> I would like to hear what others use to make form fields read only?
> And, any ideas for setting a field to read only based on user
security?
> I sometimes want to make a form entry field read only.
> Setting the object properties to read only doesn't always work.
> I guess when the form loads, my read only settings are overwritten.
> So I found tech tip example with example code to set
ExtendedProperties.
> This is works OK, just wondering what else might be available.
> Thanks
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Setting the objects properties can deliver mixed results because Epicor
is driven by the data views and not necessarily the objects.
If you want to set these kind of properties, your best bet is to set
them on the data view directly, with code, or indirectly using extended
properties.
I just had this requirement and I decided to use the extended properties
menu option, in E9, because it doesn't require any code and it would be
easier for someone in the future to "see" what fields have extended
properties.
Other than screen placement and initial bindings, I would make all
changes to the data view and don't bother with the controls.
Of cooner_55421
Sent: Tuesday, January 18, 2011 12:34 PM
Subject: [Vantage] Preferred way to make a field read only?
Hi,
And, any ideas for setting a field to read only based on user security?
So I found tech tip example with example code to set ExtendedProperties.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Jan 18, 2011 at 12:34 PM, cooner_55421 <cooner_55421@...>wrote:
> Hi,
> Thanks
