Prevent manual entry into an ultraCombo control (Ver 8.03.409C)
Thanks, that worked.
But I had changed the form from using a UD table to just using a simple epiCombo with a static list first
Would your suggestion have worked on the UltraCombo when it is actually an Adapter and not a control?
Calvin
--- In vantage@yahoogroups.com, Ted Koch <tkoch77@...> wrote:
> Calvin try this in the script editor
> Â Â Â Private Sub ProjectEntryForm_Load(ByVal sender As Object, ByVal args As EventArgs)
> Â Â Â Â Â Â ' Add Event Handler Code
> Â Â Â Â Â Â epiUltraComboC1.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList
> Â Â Â End Sub
> From: c.krusen1 <ckrusen1@...>
> To: vantage@yahoogroups.com
> Sent: Wednesday, January 18, 2012 10:14 AM
> Subject: [Vantage] Prevent manual entry into an ultraCombo control (Ver 8.03.409C)
> I added an ultraCombo (that is tied to a UD table) to the Order Entry screen.Â
> Everything seems to work(the data from UD table appears in drop down, selected dropdown item is saved to OrderHed.ShortChar06, and saved value is displayed in dropdown upon retieving an Order).
> However, the ultraCombo allows for manually typing a value in. How can I limit it to one of the values from the UD table?
> Thanks,
> Calvin
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Calvin
   End Sub
Calvin
