Preventing users from over quantity limit
The "End" table referred to in MES End Activity is in actuality the
LaborDtl table.
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> How do you access the "End" table (which is where is input is
written
> after "End Activity" is processed) to a BPM? This must be a
temporary
> table, because I cannot locate it anywhere during a BPM.
> --tj
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@> wrote:
> > Shop Warning & Op over Qty won't do what you want.
> > You need to write a VB.net customization (or BPM) to systemically
> prevent over-reporting.
> > Rob
> > --- On Thu, 10/23/08, sanfranc415 <sanfranc415@> wrote:
> > From: sanfranc415 <sanfranc415@>
> > Subject: [Vantage] Re: Preventing users from over quantity limit.
> > Date: Thursday, October 23, 2008, 12:33 PM
> > I enabled "Shop Warnings" and "Operation is Over Quantity," but it
> > only alerts the user when the Scrap is over quantity, and not the
> > "Current" is over quantity.
> > --tj
> > --- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
> wrote:
> > > It is a pretty simple customization (and I would guess also BPM)
> > exercise to trap the entry before it is saved and verify the qty
about
> > to be reported doesn't exist the open balance due on the OP.
> > > We have such a customization for MES Qty Reporting for our
Assembly
> > area jobs. Our Time & Qty Job Ops are all in our Machine Shop (CNC
> > make to stock batch runs) and we use Yield Processing in this
area -
> > and allow our people to over-report if they've incurred above
standard
> > yeild from variable length bar stock material jobs.
> > > As a result, I never tried to apply the same technique to End
> > Activity - but I don't see why it couldn't be done relatively
simply.
> > > Rob
> > > --- On Wed, 10/22/08, sanfranc415 <sanfranc415@ ...> wrote:
> > > From: sanfranc415 <sanfranc415@ ...>
> > > Subject: [Vantage] Preventing users from over quantity limit.
> > > To: vantage@yahoogroups .com
> > > Date: Wednesday, October 22, 2008, 5:24 PM
> > > I'd like to be able to prevent MES users from ENDING activity
with a
> > > quantity above the requesting quantity on an operation?
> > > I see this in the job warning, but after "enable shop alerts"
users
> > > are still have to enter a quantity above the operation
requesting
> > > quantity. I'd like to also completely disallow this behavior.
> > > Regards,
> > > --tj
I'd like to be able to prevent MES users from ENDING activity with a
I see this in the job warning, but after "enable shop alerts" users
are still have to enter a quantity above the operation requesting
Regards,
--tj
This would also be very helpful for us as well. I'm interested to see if anyone has any ideas.
Â
Dustin Biniek
UMC, Inc.
DustinB@...
Sent: Wednesday, October 22, 2008 4:24:19 PM
Regards,
--tj
It is a pretty simple customization (and I would guess also BPM) exercise to trap the entry before it is saved and verify the qty about to be reported doesn't exist the open balance due on the OP.
We have such a customization for MES Qty Reporting for our Assembly area jobs. Our Time & Qty Job Ops are all in our Machine Shop (CNC make to stock batch runs) and we use Yield Processing in this area - and allow our people to over-report if they've incurred above standard yeild from variable length bar stock material jobs.
As a result, I never tried to apply the same technique to End Activity - but I don't see why it couldn't be done relatively simply.
Rob
Regards,
--tj
--tj
> Rob
> From: sanfranc415 <sanfranc415@...>
> Regards,
> --tj
You need to write a VB.net customization (or BPM) to systemically prevent over-reporting.
Rob
--tj
> Rob
> Regards,
> --tj
How do you access the "End" table (which is where is input is written
after "End Activity" is processed) to a BPM? This must be a temporary
--tj
> Rob
> --tj
> > Rob
> > Regards,
> > --tj
