Print a PO with code
Indeed , but cheaper ;-)
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Dec 1, 2011 at 1:28 PM, bw2868bond <bwalker@...> wrote:
> Sounds like re-inventing APM
> --- In vantage@yahoogroups.com, "tkoch77" <tkoch77@...> wrote:
> > Has anyone been able to mimic the print command in epicor with code?
> What I am trying to do is have a button on the PO that will print a PO,
> save it as a PDF and then attach this PDF as an attachment in a new Outlook
> message. I'm just looking for anything that would help me get started with
> the printing action.
> > Thanks in advance,
> > Ted
Has anyone been able to mimic the print command in epicor with code? What I am trying to do is have a button on the PO that will print a PO, save it as a PDF and then attach this PDF as an attachment in a new Outlook message. I'm just looking for anything that would help me get started with the printing action.
Thanks in advance,
Ted
This can be done but let me warn you it is a feat, you need to invoke the
print method just like Epicor does(fairly easy), after that you need to use
Reflection to call the Crystal Libraries and feed the Data Set to the
Report, then you can export it as a PDF, then you need to bring in the
Interop libraries to show a message with the attachment in outlook.
It is very complex, if you are really set on doing it and you know your way
around code fairly well, let me know off the list and I'll try to help you.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks in advance,
> Ted
> Thanks in advance,
> Ted
