Awesome! Thank you Lynn, Rob & Stephan that worked great. May I ask
for one more thing? If possible, I would like to be able to pass the
purchase order number and the pack slip number to the report. I know
how to get them into variables, but how do I then pass them to the
report?
Regards,
Linda
Sent: Tuesday, February 17, 2009 7:32 PM
To: vantage@yahoogroups.com; Linda Lowney
Subject: RE: [Vantage] Print BAQ Report from Button
Rob is correct,
It can be done
The syntax is
ProcessCaller.LaunchForm(oTrans,"YourMenuID")
Create a menu id in menu maintenance this is what you
use.
The menu would be either a crystal
report or BAQ report.
Regards,
Stephen
Of robertb_versa@...
Sent: 17 February 2009 23:52
To: llowney@...; vantage@yahoogroups.com
Subject: Re: [Vantage] Print BAQ Report from Button
Might be possible by sticking a LaunchProcessCaller() statement (...hope
that's the right VB keyword... Replying on a Palm w/out access to
Vantage to verify syntax) within a Sub triggered by clicking on your
custom button control.
Never tried it personally so don't know if Crystal complicates it.
Pretty sure our primary programmer did something like this in one the
Receiving apps though (although it may not have been a BAQ report).
Hope that heads you in some useful direction. Be glad to dig deeper
tomorrow if you need.
Rob
--- Original Message ---
<mailto:llowney%40pridesigns.com> >
Sent:Tue 2/17/09 3:59 pm
To:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Subj:[Vantage] Print BAQ Report from Button
Hi Group,
I would like to print a BAQ report from a button. Would someone please
tell me if this is possible and what I need to do to make it happen.
Regards,
Linda
report?
Regards,
Linda
Rob is correct,
It can be done
The syntax is
use.
Regards,
Stephen
Rob
Hi Group,
Regards,
Linda
