I prefer to put each line in its own section and in the Section Expert
set the suppress section if blank flag.
This way the blank lines are compressed and you can use that space on
the paper in other sections.
Or
The other way is ugly but should work(I did not test the syntax in
Crystal)
If {ShipHead.shipToAddr3}<>"" and {ShipHead.shipToAddr2}<>"" and
{ShipHead.shipToAddr1}<>"" Then
{ShipHead.shipToName}+ chr(13) + {ShipHead.shipToAddr1}+ chr(13) +
{ShipHead.shipToAddr2}+ chr(13) + {ShipHead.shipToAddr3}+ chr(13) +
{ShipHead.shipToCity}+", "+{ShipHead.shipToState}+"
"+{ShipHead.shipToZip}
Else
If {ShipHead.shipToAddr3}<>"" and {ShipHead.shipToAddr1}<>"" and
{ShipHead.shipToAddr2}= "" Then
Else
......................... The remaining combinations ..........
Hope this helps
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:
dale.schuerman@...
<BLOCKED::blocked::mailto:
dale.schuerman@...> (email)
http://www.ramsys.com <BLOCKED::blocked::
http://www.ramsys.com/>
(website)
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of dswmaom
Sent: Monday, February 22, 2010 4:35 PM
To:
Subject: [Vantage] Printing Addresses
I am choking on a simple Crystal formatting issue having to do with
printing addresses. Vantage allows addr1,2,3 but some of our addresses
only use addr1. Some use addr1 and 2.
What I am wanting to do is to print only the non-blank addresses and
have the city-state-zip print below the address lines with no blank
lines.
I have a formula field setup as follows:
If {ShipHead.shipToAddr1}<>"" Then{ShipHead.shipToAddr1}+ chr(13) +
If{ShipHead.shipToAddr2}<>"" Then{ShipHead.shipToAddr1}+ chr(13) +
If {ShipHead.shipToAddr3}<>"" Then{ShipHead.shipToAddr1}+ chr(13) +
If {ShipHead.shipToCity}<>"" Then{ShipHead.shipToCity}+",
"+{ShipHead.shipToState}+" "+{ShipHead.shipToZip}
Else ""
It prints:
name
addr1
addr2
but nothing else...
Apparently when it hits the blank addr3 it wigs out and doesn't print
the city-state-zip. I added the last "if" to check for a blank city not
because any of them would be blank, but in order to seperate it from the
"if" preceding it.
Any advice would be greatlyl appreciated.
Dale.
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to
