Printing bar codes from Vantage
Crystal Reports would be the default method. The bar code is just a
font, "Dataworks Bar 39". You need to concatenate an "*" at each end
of the bar code so the scanner knows where to start and stop. You
can see some examples in stock reports such as job traveler or
receipt labels just to name a couple.
--- In vantage@yahoogroups.com, "Michelle C. Grman" <mcgrman@...>
wrote:
> How do you print bar codes from Vantage 8.0.3...? Is there a bolt-
on
> required?
> Michelle C. Grman
> Assistant Controller
> KERUSSO
> The Greek word means - To herald divine truth as a public crier; to
> preach the gospel.
> P.O. Box 32
> Berryville, AR 72616
> Phone: 870-423-6242 Ext. 222
> Fax: 870-423-3568
> Web Site: www.kerusso.com
> Revolutionize your jewelry sales with the Beacon Accessory Center:
> "The Beacon is a SERIOUS MARGIN MAKER! We've sold half of the
product in
> less than a month!"
> -Ron Kuzman, Mgr., Sonrise Christian
> CONFIDENTIALITY STATEMENT:
> This message, from Kerusso Inc., contains information
> which is privileged and confidential and is solely for the use of
> the intended recipient. If you are not the intended recipient, be
> aware that any review, disclosure, copying, distribution, or use
> of the contents of this message is strictly prohibited. If you have
> received this in error, please destroy it and notify us immediately
> at: 800-424-0943
How do you print bar codes from Vantage 8.0.3...? Is there a bolt-on
required?
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
"The Beacon is a SERIOUS MARGIN MAKER! We've sold half of the product in
less than a month!"
at: 800-424-0943
