I was able to make it work on the datamax printers. I had to go
into the driver options and override the manufacturer
Specifications.
I set the max media and max print areas to 8.5" Then I set the
Printer settings to 8.5 X 11. Everything printed fine. Not sure
why though.
Thanks for everyones suggestions.
--- In vantage@yahoogroups.com, "Michael McWilliams"
Specifications.
why though.
>move.
> I am following this and I see two sets of details. One on the left
> that I can move and one on the right that is blue and I cannot
>what
> --- In vantage@yahoogroups.com, "Dave Pfiester" <dpfiester@>
> wrote:
> > Michael,
> > I have printed labels printing Zebra LP2844 printers. I think
> > you need to do is in Crystal change the form borders. Below is aLaserjet
> help
> > document that I received from Epicor tech support that helped me
> with
> > the issue you are describing. Hope it helps.
> > Summary: Labels are not printing to the Label printer
> > Book: Support Solutions
> > Page: 6110MPS
> > Labels
> > Crystal Reports
> > Label printer
> > Problem Description:
> > When either the Label printer (Intermec or Zebra) or the
> > (HPLaserjet5) is set as default in Windows, the labels willeither
> > print blank, or receive an error message in the System Monitorto
> runprints
> > the report in preview mode. Once you run the report in preview
> mode
> > from the System Monitor, the label previews fine, but still
> > blank if you attempt to print it from the preview.Page
> > Problem Resolution:
> > The labels will print as long as the Label printer driver's
> Printing
> > Preferences -> Page Setup is set to 4x6 as default as the
> > standard/canned label was developed for the 4x6 size. (Or the
> > Setup needs to match to the label size of what was developed inthe
> > Crystal Reports when creating labels from scratch.)
> > Also in Crystal Reports in design mode for the Label, the margin
> > width can not be any larger than 3.7. To access this in Crystal:
> > 1. Bring up the Label in Crystal Reports
> > 2. In the Section area (Grey area to the left) right-click in
> > Details section and choose Section Expert.in.
> > 3. The sections (Report Header, Page Header, Details, etc.)
> > Highlight the Details section and choose the Layout tab on the
> right.
> > 4. The Details size Width can not be anything higher than 3.7
> > for a Standard 4x6 portrait size label.the
> > 5. Hit Ok.
> > Back in Design mode of the Label, some of the fields maybe off
> > page on the right hand side margin. These fields may need to beand
> > adjusted or made smaller so they are not running off the right
> side
> > of the margin page. Once these adjustments have been made, the
> > label should print directly to the Label printer without error
> > with data printing on it.a
> > Additional Information:
> > Some Label Printers or Label sizes may require adjustment of the
> > Layout Width even smaller.
> > 8.00.805
> > David Pfiester
> > Systems Accountant
> > NuStep Inc.
> > Phone: 734-769-3939 x150
> > Fax: 734-769-8180
> > <mmcwilliams22@> wrote:
> > > Having a strange issue now .. If I set my default printer to
> > > regular laser printer and do a print preview then choose thetag
> > > printer and set it's properties to the size it will work.the
> > > But when the viewer used the tag printer as the default with
> > > same setting it will not. Just hoping maybe someone can helpme
> > > > Have datamax printers, I have tried M4203, Allegro 2, E4203.
> > > > None of them will work
> > > > --- In vantage@yahoogroups.com, Todd Caughey <caugheyt@>
> > > > >printer
> > > > > Just out of curiosity...what brand and model of label
> printer?
> > > > > I had a similar issue once upon a time with a Zebra
> > thaton
> > > > no amount of driver tweaking was going to fix. Ended up it
> > > > was "required" to lie to the driver about the firmware rev
> level
> > > on
> > > > the printer. It would print great from everything (Word,
> Excel,
> > > CR
> > > > Developer,...) except CR runtime from within Vantage.
> > > > > -Todd C.
> > > > > ________________________________
> > > > > From: vantage@yahoogroups.com
> [mailto:vantage@yahoogroups.com]
> > > On
> > > > Behalf Of Michael McWilliams
> > > > > Sent: Tuesday, July 10, 2007 8:36 AM
> > > > > To: vantage@yahoogroups.com
> > > > > Subject: [Vantage] Re: PRINTING
> > > > > Well I updated everything. Still I print the material tags
> to a
> > > 4x6
> > > > > label from crystal and it works fine. When I print from
> runtime
> > > it
> > > > > is actually
> > > > > making my printer fault after it only prints a portion of
> the
> > > label
> > > > > but in the wrong spot. I am wondering what could be going
> > thatprinter
> > > > > is different from the two. I would think is was the
> if ICrystal .dll
> > > > > could not print it from either spot.
> > > > > --- In vantage@yahoogroups.com<mailto:vantage%
> > > > 40yahoogroups.com>, "Michael Barry" <mbarry@> wrote:
> > > > > > It looks like you may have a mismatched set of
> > > > > files. You canfull
> > > > > > solve the issue either by downloading the latest service
> > > pack/hot
> > > > > fix for
> > > > > > your version of Crystal's runtime files or install the
> > > > > version on eachonly
> > > > > > workstation that needs to print the bar coded reports.
> > > > > > Regards,
> > > > > > Michael
> > > > > > Michael Barry
> > > > > > Aspacia Systems Inc
> > > > > > 866.566.9600
> > > > > > 312.803.0730 fax
> > > > > > <http://www.aspacia.com/> http://www.aspacia.com/
> > > > > > This email, and any attachments thereto, is intended
> forcopy
> > > use
> > > > > by the
> > > > > > addressee(s) named herein and may contain legally
> privileged
> > > > and/or
> > > > > > confidential information. If you are not the intended
> > recipient
> > > > > of this
> > > > > > email, you are hereby notified that any dissemination,
> > > > > distribution or
> > > > > > copying of this email, and any attachments thereto, is
> > strictly
> > > > > prohibited.
> > > > > > If you have received this email in error, please
> immediately
> > > > > notify me by
> > > > > > telephone and permanently delete the original and any
> ofwhen
> > > any
> > > > > email and
> > > > > > any printout thereof.
> > > > > > From: vantage@yahoogroups.com<mailto:vantage%
> > > 40yahoogroups.com>
> > > > [mailto:vantage@yahoogroups.com<mailto:vantage%
> > 40yahoogroups.com>]
> > > On
> > > > > Behalf Of
> > > > > > Michael McWilliams
> > > > > > Sent: Friday, July 06, 2007 6:48 AM
> > > > > > To: vantage@yahoogroups.com<mailto:vantage%
> 40yahoogroups.com>
> > > > > > Subject: [Vantage] PRINTING
> > > > > > I am having a heck of a time printing from Vantage.
> > > > > > When I Print from Crystal my form prints correct, but
> II
> > > > > it
> > > > > > from crystal report viewer it does is way different and
> domay
> > > not
> > > > > get
> > > > > > bar codes. Any ideas where I can start looking for the
> problem
> > > > > > [Non-text portions of this message have been removed]
> > > > > The information contained in this E-mail message and any
> > > documents
> > > > which may be attached are privileged and confidential, and
> bedisclosure
> > > > protected from disclosure.
> > > > > Please be aware that any use, printing, copying,
> or
> > > > dissemination of this communication may be subject to legal
> > > > restriction or sanction. If you think you have received this
> > > message
> > > > in error, please reply to the sender.
> > > > > For more information please visit www.harveyvogel.com
