Printing Checks Help!
I print my checks on an HP2200dtn, but I haven't ever had this problem. Our
forms are controlled by PrintBoss software, and the only time I had a
problem was when I ran out of checks and then somebody else quequed a print
job. I hope you find your answer soon!
Rebecca
Sent: Thursday, December 18, 2003 6:36 PM
Subject: RE: [Vantage] Printing Checks Help!!!!
We have one computer that this happens on and, of course, it is our AP
person who needs to print the most. The problem seems to be a cache
overload
from her computer, but we have never been able to pin point the problem.
There are two other computers in Accounting and the checks print fine from
those. When the AP clerk has to do a large check run, she prepares the
batch, then we actually process and print checks from one of the other
computers.
Good luck,
Karen Brodniak
Accounting Manager
425-742-7011 X44
Fax 425-353-8945
karen.brodniak@...
Sent: Thursday, December 18, 2003 2:05 PM
Subject: [Vantage] Printing Checks Help!!!!
Hi and Season's Greetings,
I am trying to print checks.
They are Epicor stock,3 part Laser Printer Checks.
The printer is an HP2200.
It will print 10 or less and stop.
So that is less than 30 sheets printed.
No paper jam. The error reported does not explain
what the problem is.
HP tech support says there is no problem with the printer.
They are right I can print a paper tray non stop of
regular paper.
Some how it knows that there are checks being run.
How do you print checks.
What printer do you use?
Do you have trouble with your check runs?
Please help, everyone wants a check, Vendors especially.
Otherwise happy holidays.
John Mansfield
General Sheet Metal
and
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Yahoo! Groups Links
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
regular paper.
John Mansfield
General Sheet Metal
John,
I take it you can print the checks on standard white paper.
It only fails when the checks are being printed.
How much do you use/how old is the printer.
It almost sounds as if it is a paper feed problem.
Open your printer and try to clean the pick up roller(s)/ or pad(s) at the paper tray.
These things generally look like rubber, so go after the rollers and/or pads directly associated with the paper tray.
They could be dirty or worn and may have a problem with the type of paper Epicor uses for your checks.
If they are worn you will need to call for service to replace them
Rich
----- Original Message -----
Sent: Thursday, December 18, 2003 5:04 PM
regular paper.
John Mansfield
General Sheet Metal
person who needs to print the most. The problem seems to be a cache overload
computers.
Good luck,
Karen Brodniak
Accounting Manager
425-742-7011 X44
Fax 425-353-8945
karen.brodniak@...
regular paper.
John Mansfield
General Sheet Metal
Yahoo! Groups Links
