Printing Checks in Vantage
Thank you all for your insight on laser checks. I think we are going to
digitized signatures and add them to the Crystal Report. Thanks all again!
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Sent: Friday, November 02, 2001 12:51 PM
Subject: RE: [Vantage] Printing Checks in Vantage
Same here but we use duplicate check copies and our founder's wife is only
89 years old and still signs all checks.
Jeni Wilson
Boyer Machine
Sent: Friday, November 02, 2001 1:29 PM
Subject: Re: [Vantage] Printing Checks in Vantage
We use a laser printer that is dedicated to A/P and payroll and print
150/200 checks per week. We still print plain paper copies of payroll checks
to put in employee file (we like the paper thing). One of our founders, 91
year old lady still signs all checks by hand. Bless her heart.
Mike :-)
>From: Mario Aguirre <maguirre@...>
>Reply-To: vantage@yahoogroups.com
>To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
>Subject: [Vantage] Printing Checks in Vantage
>Date: Fri, 2 Nov 2001 10:26:00 -0600
>We print an average of 350 and some A/P and payroll checks every week. We
>are about to increase this amount considerably once we incorporate the
>payroll from one of our companies currently in ADP. We use a dot matrix
>printer and a signature machine. Adjusting Vantage settings was not fun and
>dealing with the signature machine is close to hell. We are considering
>moving to laser printed checks, yet we still have to deal with the
>signature
>machine.
>Is anybody in the group using laser checks and how are you dealing with
>signatures, filing copies, etc.?
>Mario Aguirre
>Lakin General
>Chicago, IL 60657
>Ph: 773-871-9631
>[Non-text portions of this message have been removed]
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
moving to laser printed checks, yet we still have to deal with the signature
machine.
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
We use laser printers exclusively. Gave up the dot matrix and signature
machine, unfortunately for those who are now manually signing checks.
However, direct deposit of payroll and A/P checks makes for less and less
checks to sign. We just re-run the A/P check run to generate plain paper
versions of our checks for filing copies. Never did keep filing copies of
Payroll checks, but could use the same process for them.
Deb Wilmoth
Controller
Reeder & Kline Machine Company, Inc.
Vantage 5.0
Sent: Friday, November 02, 2001 11:26 AM
To: 'vantage@yahoogroups.com'
machine.
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Another option is to print the checks with the signature on them. There is
security on printing checks (although the security manager would also have
access). Laser printing checks is much better than dot matrix. We have
been doing it for 5 years and have had very few printer problems. I would
recommend watching your checks print (in case of printing problem or lack
of ink) and having a dedicated printer (so someone else doesn't decide to
print while the checks are loaded). I think we have run out of toner once
and had the print jam once or twice in 5 years (30,000 checks).
Alex Neutgens
Controller
Circuit Check, Inc.
763-694-4110
Sent: Friday, November 02, 2001 10:26 AM
signature
machine.
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Mario:
We are on 4.0, using laser checks with copies (they come already combined),
don't have any problems except once in a while, the laser printer will get
dirty and dried out and grab more than one check-but that is a mechanical
problem. We're just using an Hp 1100.
On the signature side: our bank issued a signature stamp (probably cost $25
or so), which is kept locked up and used to sign our paychecks-accounting
mgr signs AP checks. The accountant has it in some secret hiding place and
won't even get it out if anyone is in the room.
Lydia
lcoffman@...
Sent: Friday, November 02, 2001 8:26 AM
machine.
Mario Aguirre
Lakin General
Chicago, IL 60657
Ph: 773-871-9631
Mike :-)
>signature
>machine.
>Mario Aguirre
>Lakin General
>Chicago, IL 60657
>Ph: 773-871-9631
>... We are considering moving to laser printed checks, yet we still have
>to deal with the signature machine.
If you're on Vantage 4 or higher, you can modify the Crystal form and put a
bitmap of the signature in there to print directly on the check. If you'd
like a false sense of security, you could have the signature burned onto a
custom font cartridge for your printer, so the accounting guy has something
to pull out and lock up ;)
We buy laser forms with a duplicate sheet interleaved with each real
check. This can be troublesome, because you have to remember to select
"copies= 2" every time you print. Vantage and Windoze will ignore any
attempts to select 2 as a permanent default. As a work around, I was able
to program a string substitution into the printer's network adapter to
always force two copies.
-Wayne Cox
Jeni Wilson
Boyer Machine
Mike :-)
>signature
>machine.
>Mario Aguirre
>Lakin General
>Chicago, IL 60657
>Ph: 773-871-9631
Wow!!!! Sure hope they enjoy working!!! I rather thought that I'd like to
retire and play some day. I'd like to smell more roses and spend more time
petting the bunnies! So much to do so little time........ :)
Deb Wilmoth
Controller
Vantage 5.0
Sent: Friday, November 02, 2001 1:51 PM
Jeni Wilson
Boyer Machine
Mike :-)
>signature
>machine.
>Mario Aguirre
>Lakin General
>Chicago, IL 60657
>Ph: 773-871-9631
