Printing Documents with Job Traveler
I don't know if you have APM (Advanced Print Management), but I am pretty sure if you send a Word Document through, it will be converted to one Tiff file (for all pages of the Word Doc)....
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Numbers
Sent: Thursday, December 01, 2011 2:33 PM
Subject: RE: [Vantage] Printing Documents with Job Traveler
Thanks for the help. I am getting closer. But.... My original document
that I need to print along with the Job Traveler is multiple pages. The
document is a docx. I have not been successful in finding any image type
that treats the entire document as one document. For instance the
conversion programs I have tried that goes from docx or pdf to tiff all end
up with a separate tiff for each page. Is there any image types that I can
convert to that will keep my finished document as 1 document? Or is there
another solution available?
Thanks again, I am learning a lot on this project.
Mike
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Jose Gomez
Sent: Thursday, December 01, 2011 11:29 AM
Subject: Re: [Vantage] Printing Documents with Job Traveler
Use an Image i've done it successfully using an Image.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...<mailto:jose%40josecgomez.com>
http://www.josecgomez.com
On Thu, Dec 1, 2011 at 11:26 AM, Mike Numbers <mnumbers@...<mailto:mnumbers%40cignys.com>> wrote:
> Jose,
> I am having a problem similar to Karen. When I create a OLE object, I
don't
> see any option to use a formula or variable to point to different objects
> based on the data. I have tried both PDF, which appears not to be
> available, but I have also tried to add an OLE object with the document
> being a docx. I am creating the OLE object by Insert, OLE Object,
selecting
> the object type, create from file. This seems to make a static object with
> no option to change based on data. I am using CR 11.5.3.417.
> Am I missing something?
> Mike
> Of
> Karen Schoenung
> Sent: Thursday, December 01, 2011 11:10 AM
> OK, I guess it is the pdf part then...Everything I see online says it
can't
> be done with pdfs and my trials also show that...I expect it will be a
much
> bigger project but will need to be a discussion if we want to attach the
> items...We will need to change them to tiffs or other image types...
> Thanks,
> Karen
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of Jose Gomez
> Sent: Thursday, December 01, 2011 10:01 AM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Karen,
> I haven't tried it with PDF's but I know it works with images, is there a
> way you can save your PDF's as TIFFS? or something like that? Then the
> logic
> on the Graphic Location should work.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...<mailto:jose%40josecgomez.com> <mailto:jose%40josecgomez.com>
> On Thu, Dec 1, 2011 at 10:53 AM, Karen Schoenung <
> kschoenung@...<mailto:kschoenung%40fisher-barton.com> <mailto:kschoenung%40fisher-barton.com> >
> wrote:
> > Jose,
> > I have a question or two...If I have a static path and just the file
> > name changes based on part & revision, I can make a formula in Crystal
> > based on that path. But, I do not know how to add the OLE object. When
> > I try, I have to put in an existing or create new...Then, I change the
> > graphic location to be my path from the formula, but the OLE object
> > does not change...What are you saying is possible that I did not find
> > ability to do yet online searching google? Am I missing a step or why
> > does this not work as you describe below? I don't think just using a
> > UD table to already have the path is the issue - but maybe I am
> incorrect?
> If so, can you explain why?
> > Thank you,
> > Karen
> > Sent: Wednesday, November 30, 2011 3:52 PM
> > Add the location of the PDF Files to a UD Table and Link it back to
> > the finished Part, Modify the Traveler RDD to Include that UD table,
> > in Crystal Use the OLE Object option to bring in the PDF in the right
> > place :)
> > Let me know if you have any questions.
> > *Jose C Gomez*
> > *Software Engineer*
> > On Wed, Nov 30, 2011 at 3:59 PM, mike.numbers <mnumbers@...<mailto:mnumbers%40cignys.com>
> <mailto:mnumbers%40cignys.com> > wrote:
> > > I am trying to figure out the easiest way to print some documents
> > > (PDF) along with the Job Traveler. The documents are specific to the
> > > finished part. If anyone is currently doing this or knows how to do
> > > this I would appreciate any and all advice.
> > > Epicor 9.04.507A
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
I am trying to figure out the easiest way to print some documents (PDF) along with the Job Traveler. The documents are specific to the finished part. If anyone is currently doing this or knows how to do this I would appreciate any and all advice.
Epicor 9.04.507A
Add the location of the PDF Files to a UD Table and Link it back to the
finished Part, Modify the Traveler RDD to Include that UD table, in Crystal
Use the OLE Object option to bring in the PDF in the right place :)
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Epicor 9.04.507A
Jose,
I have a question or two...If I have a static path and just the file name changes based on part & revision, I can make a formula in Crystal based on that path. But, I do not know how to add the OLE object. When I try, I have to put in an existing or create new...Then, I change the graphic location to be my path from the formula, but the OLE object does not change...What are you saying is possible that I did not find ability to do yet online searching google? Am I missing a step or why does this not work as you describe below? I don't think just using a UD table to already have the path is the issue - but maybe I am incorrect? If so, can you explain why?
Thank you,
Karen
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Add the location of the PDF Files to a UD Table and Link it back to the finished Part, Modify the Traveler RDD to Include that UD table, in Crystal Use the OLE Object option to bring in the PDF in the right place :)
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Epicor 9.04.507A
Karen,
logic on the Graphic Location should work.
*Jose C Gomez*
*Software Engineer*
E: jose@...
kschoenung@...> wrote:
> Jose,
> Thank you,
> Karen
> Of Jose Gomez
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Epicor 9.04.507A
OK, I guess it is the pdf part then...Everything I see online says it can't be done with pdfs and my trials also show that...I expect it will be a much bigger project but will need to be a discussion if we want to attach the items...We will need to change them to tiffs or other image types...
Karen
Karen,
I haven't tried it with PDF's but I know it works with images, is there a way you can save your PDF's as TIFFS? or something like that? Then the logic on the Graphic Location should work.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Dec 1, 2011 at 10:53 AM, Karen Schoenung < kschoenung@...> wrote:
> Jose,
> Thank you,
> Karen
> place :)
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Epicor 9.04.507A
Jose,
I am having a problem similar to Karen. When I create a OLE object, I don't
being a docx. I am creating the OLE object by Insert, OLE Object, selecting
Mike
Karen Schoenung
Karen
Karen,
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
kschoenung@... <mailto:kschoenung%40fisher-barton.com> >
wrote:
> Jose,
> Thank you,
> Karen
> place :)
> *Jose C Gomez*
> *Software Engineer*
> > Epicor 9.04.507A
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Dec 1, 2011 at 11:26 AM, Mike Numbers <mnumbers@...> wrote:
> Jose,
> Mike
> Of
> Karen Schoenung
> Thanks,
> Karen
> Karen,
> logic
> *Jose C Gomez*
> *Software Engineer*
> wrote:
> > Jose,
> incorrect?
> > Thank you,
> > Karen
> > place :)
> > *Jose C Gomez*
> > *Software Engineer*
> > > Epicor 9.04.507A
And on the OLE object, choose format graphic, picture tab, then middle of the window is graphic location button...
Sent: Thursday, December 01, 2011 10:29 AM
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Jose,
> don't see any option to use a formula or variable to point to
> different objects based on the data. I have tried both PDF, which
> appears not to be available, but I have also tried to add an OLE
> object with the document being a docx. I am creating the OLE object by
> Insert, OLE Object, selecting the object type, create from file. This
> seems to make a static object with no option to change based on data. I am using CR 11.5.3.417.
> Mike
> Behalf Of Karen Schoenung
> Thanks,
> Karen
> Karen,
> *Jose C Gomez*
> *Software Engineer*
> http://www.josecgomez.com <http://www.linkedin.com/in/josecgomez>
> wrote:
> > Jose,
> incorrect?
> > Thank you,
> > Karen
> On
> > right place :)
> > *Jose C Gomez*
> > *Software Engineer*
> > > Epicor 9.04.507A
Mike
Jose Gomez
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Jose,
don't
selecting
> Mike
> Of
> Karen Schoenung
can't
much
> Thanks,
> Karen
> Karen,
> logic
> *Jose C Gomez*
> *Software Engineer*
> wrote:
> > Jose,
> incorrect?
> > Thank you,
> > Karen
> > place :)
> > *Jose C Gomez*
> > *Software Engineer*
> > > Epicor 9.04.507A
We were hoping to do something similar in Vantage as well but haven't found a method to date either... We print shop floor drawing collated with the traveler assemblies and some are multiple pages and they go back and forth between 8 ½ x 11 and 11 x 17... We have been doing this sometime but are using a software called PlanetPress Watch to accomplish this... it works flawless, but would have been nice to just do it natively in vantage and not have another piece in the game.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Mike
Jose Gomez
*Jose C Gomez*
*Software Engineer*
> Jose,
don't
selecting
> Mike
> Of
> Karen Schoenung
can't
much
> Thanks,
> Karen
> Karen,
> logic
> *Jose C Gomez*
> *Software Engineer*
> wrote:
> > Jose,
> incorrect?
> > Thank you,
> > Karen
> > place :)
> > *Jose C Gomez*
> > *Software Engineer*
> > > Epicor 9.04.507A
If you are using word or something common you can run a process that will
convert all pages to images or something friendly then add entries to a UD
table..
*Jose C Gomez*
*Software Engineer*
E: jose@...
> forth between 8 � x 11 and 11 x 17... We have been doing this sometime but
> Rob Bucek
> FAX: (715)284-4084
> Of Mike Numbers
> Mike
> Jose Gomez
> *Jose C Gomez*
> *Software Engineer*
> > Jose,
> don't
> selecting
> with
> > Mike
> > Of
> > Karen Schoenung
> can't
> much
> > Thanks,
> > Karen
> > Karen,
> > logic
> > *Jose C Gomez*
> > *Software Engineer*
> > wrote:
> > > Jose,
> > incorrect?
> > > Thank you,
> > > Karen
> > > place :)
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > > Epicor 9.04.507A
> have
