Printing from Epicor to a PDF with OCR turned on
How does one go about printing SSRS reports and Invoices from Epicor to a PDF with OCR enabled?
What is the objective here? Reports can be downloaded as PDF. How does OCR come into picture?
PDF generated is a text pdf. You should be able to read it without OCR if you are trying to automate something with generated PDF
If I print a 180 page report for example to a PDF. I can not search the document until I run an OCR scan on it first. I use a Foxit PhantomPDF driver and reader in this example.
I figured it out, set printing output to EMF then print to PDF.
