Printing in Vantage 8.03
I am experiencing the same problem with printing standard Crystal
reports. ( I WAS able to Production Detail report, so it seems to be
Crystal). I ensured that Crystal Reports XI R2 has been installed.
Also I did select "Everyone" (NOT "Just me") as instructed by Epicor.
If anyone finds a solution to this major problem, please let me know.
I will do the same.(I have a call into Epicor support) thanks!
phochkins@...
--- In vantage@yahoogroups.com, "Paul V. Blais" <pblais@...> wrote:
> There could be so many things. Can you not print everything, or
just
> crystal reports? If you are on 304 and can print a production
detail
> report then it's a crystal issue. If it is, is R2 Crystal runtime
> installed? Was it installed as "Just Me" or "Everyone"? If you
can't
> there is an issue with a file path in your agent, or a sharing issue
> with your folders.
Behalf
> Of Dan Ernst
> Sent: Tuesday, January 23, 2007 8:19 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Printing in Vantage 8.03
> I have just converted data from 6.1 to 8.03 and am having trouble
> printing reports. It was working when I converted data a month ago.
I
> set up the system agent exactly as it was before. Only thing that
> changed is I was told by Epicor to edit my registry sine Progress
and
> Open edge was using the same port number 20931. I have changed it
to
> where Open edge is using 20555. Below is the error message I get
when
> I open up system monitor
> Error Detail
> Load report failed.
> Stack Trace
> at
CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.EnsureDoc
> umentIsOpened()
> at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load
> (String filename, OpenReportMethod openMethod, Int16 parentJob)
> (String filename, OpenReportMethod openMethod)
> at Epicor.Mfg.Lib.Report.EpiCrystalViewer..ctor(String rptFile,
> String dataFile, PrinterSettings ps, String rTitle)
> String dataFile, String rTitle)
> at
> Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.previewCrystalReport()
> Inner Exception
> The device is not ready.
> Inner Stack Trace
> at
CrystalDecisions.ReportAppServer.ClientDoc.ReportClientDocumentClass.O
> pen(Object& DocumentPath, Int32 Options)
> at
> CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.Open
> at
> umentIsOpened()
> Thanks
> Dan Ernst
> Correct Craft, Inc.
printing reports. It was working when I converted data a month ago. I
changed is I was told by Epicor to edit my registry sine Progress and
Open edge was using the same port number 20931. I have changed it to
where Open edge is using 20555. Below is the error message I get when
Error Detail
Load report failed.
Stack Trace
at
umentIsOpened()
at
Inner Exception
Inner Stack Trace
at
at
at
umentIsOpened()
Dan Ernst
Correct Craft, Inc.
There could be so many things. Can you not print everything, or just
crystal reports? If you are on 304 and can print a production detail
installed? Was it installed as "Just Me" or "Everyone"? If you can't
with your folders.
Of Dan Ernst
Error Detail
Load report failed.
Stack Trace
at
umentIsOpened()
at
Inner Exception
Inner Stack Trace
at
at
at
umentIsOpened()
Dan Ernst
Correct Craft, Inc.
