Printing - Invalid character in a Base-64 string
Correct I get the same thing every once in a while.  If you try to open the XML in IE, it will tell you the line and column the character is at.  Then I open with Notepad ++ and find the character.  Then you have to edit the data, it could be in the Part Master, Order Entry, PO Entry, Job Entry....
From: vantage@yahoogroups.com [vantage@yahoogroups.com]
Sent: Friday, November 20, 2015 3:42 PM
Subject: Re: [Vantage] Printing - Invalid character in a Base-64 string
This can happen if an odd character is in the XML.
e.g. a description copied into the part master from some other source.
If this is the same case for you...
There is an answerbook on Epicweb that describes the problem.
Open the XML with a viewer to identify offending record ID / field in the XML.
Fix the field in E9 Maintenance... a funky part description pasted from an external source
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
<!-- #ygrps-yiv-1383001399 _filtered #ygrps-yiv-1383001399 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1383001399 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1383001399 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-1383001399 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-1383001399 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-1383001399 #ygrps-yiv-1383001399 p.ygrps-yiv-1383001399MsoNormal, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399MsoNormal, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-1383001399 a:link, #ygrps-yiv-1383001399 span.ygrps-yiv-1383001399MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-1383001399 a:visited, #ygrps-yiv-1383001399 span.ygrps-yiv-1383001399MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-1383001399 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1383001399 code
font-family:“Courier New”;}
#ygrps-yiv-1383001399 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-1383001399 tt
#ygrps-yiv-1383001399 span.ygrps-yiv-1383001399HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399attach, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399attach, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399bold, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399bold, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399green, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399green, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399replbq, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399replbq, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399ad, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399ad, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399underline, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399underline, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1383001399 span.ygrps-yiv-1383001399yshortcuts
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399ad1, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399ad1, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399ad2, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399ad2, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1383001399 p.ygrps-yiv-1383001399underline1, #ygrps-yiv-1383001399 li.ygrps-yiv-1383001399underline1, #ygrps-yiv-1383001399 div.ygrps-yiv-1383001399underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1383001399 span.ygrps-yiv-1383001399yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-1383001399 span.ygrps-yiv-1383001399yshortcuts2
font-weight:normal;}
#ygrps-yiv-1383001399 span.ygrps-yiv-1383001399EmailStyle34
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-1383001399 .ygrps-yiv-1383001399MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1383001399 div.ygrps-yiv-1383001399WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-1383001399 ol
{margin-bottom:0in;}
#ygrps-yiv-1383001399 ul
When a user tries to print a report, they are getting an application error ‘invalid character in a Base-64 string’. We tried clearing client cache and changing Windows XP to service pack 3 compatibility but that did not resolve the issue. Has anyone seen this error before?
