Sorry if this has been brought up previously. Searching in Yahoo groups isn't working at the moment & I'm trying to get this resolved.
We're on Vantage 8.03.404B sitting on a Progress db. Users are unable to print preview or print native-Vantage reports. We've bounced the server twice, and I've verified that all app servers are up & running.
I see where Vantage is outputting the xml for a given Crystal Report while trying to print or print preview, but nothing happens.
What is the connection between that xml & the Crystal Report? How is that report generated?
THANKS in advance for any/all help!!!
Hi! There is a big probably that the report are not in cause.... Go to: system management / system monitor/ go to the action menu and select "display all task". Then, go in the report tab and select one of the report. You can then click print preview to see if the old report the person tried to print is visible to you.
If not: maybe the Crystal report viewer version is not the good one on the server and the computer were epicor is.
If not, do and look at the xml of the report. See if you can see all the xml information or if there is an error at the end of it. If so, it means the Crystal report is not good anymore.
To go and see the Crystal report: \\epicor\Epicor905\Server\reports. Open the Crystal report in cause and see what is going on if you make a preview of this one directly in Crystal.
You can always look at the link between the menu and the Crystal report in report style. You have a lot of information in report data definiton. All in the "company" menu.
Jason Claggett
Vice President of Technology
2W Technologies, Inc.
Epicor Certified Partner
312.533.4033 x8039
jason@...<mailto:jason@...>
[Description: bus_prtnr_2C_vert_sm]
