I found something else to watch for after a dump and load when I did my first one last month. I didn't find my problem until over a week after the dump and load and couldn't restore either. I had tested the process ahead of time, but didn't check employee hire and birth dates. Everyone born/hired between 1950 and 1969 had their birth and hire years changed to 2050-2069. In my case tech support was able to send me a fix-it program that fixed the dates. As I suspected, it had to do with the year parameter. Next time, I'll have to play with that parameter to make sure the dump and load doesn't do it again. The only problem it caused was the two weeks where our 401k/pension projections as the bank were off. I was projected to get over 3 million dollars a month, but on the down side my projected retirement date was something like 2120!Yikes!
Sue
Sue
--- In vantage@yahoogroups.com, Ned <TechnoBabbly@...> wrote:
> Other than manually changing it in there, there isn't anything you can do.
> I suspect you may have done your dump and load in ISO and your DB is UTF or
> vice versa, that's the only time I have seen something like that happen, and
> also why I generally do a test D&L and restore it to a test DB for testing
> prior to the actual D&L of the live system.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> justincalbraze
> Sent: Wednesday, October 10, 2012 5:37 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Problem after Dump and Load (symbols in operation text)
> An operation had been created using a check box symbol like:
> U+2610 ☐ ballot box
> After a dump and load, it shows up as a ? in all the operations.
> Is there a way to fix the problem other than restoring to DB pre-dump and
> load? Four days passed before someone noticed the issue, so having to
> rollback that far would be less than ideal...
> Thanks for any ideas,
> Justin
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
