What specific PO entry dataview boolean fields are you tring to set (&/or what checkbox controls)?
Also - What version are you on?
PO entry is (one of many) 'works in process' as successive versions have gone thru significant changes.
Rob
--- Original Message ---
Sent:Tue 9/15/09 4:39 pm
To:<vantage@yahoogroups.com>
Subj:[Vantage] Problem: Checkbox select/deselect in record of PODetail table triggers checkbox select/des
All..I need a dot net code that can behave as outlined in subject. Anyone
who had to perform a similar task and may have used dot net or BPM or
anything please reply ASAC.
Thanks in advance.
Best Regards,
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@...
607-754-9187 ext. 3078
www.ergpower.com
Rob
Thanks in advance.
Best Regards,
Herby Dallard
hdallard@...
www.ergpower.com
