I jumped from .808f to .809a.
I installed 809A yesterday and it fixed some issues I was having w/
the smart string but I saw where it was creating another even bigger
problem...
I have a configured part called the Phoenix. I have two revisions,
blank and "x". (Why blank?? because that is what the manual said to
do early on but they changed their minds and so I copied and created
rev.X). I noticed that in rev X, all of the "pull as assembly" parts
in my BOM have no supporting ops or mtl. But, if you look at the
blank rev, you can see the expected operations and mtl listed for
the "pull as assembly" parts.
I have checked the eng w.b. for the parts listed in the BOM as "pull
as assembly" on the configurated Phoenix. They only have one rev
and it has ops and mtl.
Is anyone seeing the same thing or similar issues? Have you figured
out how to fix it?
Thanks, John
problem...
out how to fix it?
Thanks, John
John - Were you on 809 before going to 809A? Or did you jump up a couple of
releases when you installed 809A?
Nothing in the 809A Change List about product configurator changes. Did it
work under 809?
Chuck Andrews
Iridium Industries, Inc.
One Forge Road
E. Stroudsburg, PA 18301
570-476-8800 Ext 14
Controller@...
_____
JohnBob
Sent: Friday, August 25, 2006 10:48 AM
Subject: [Vantage] Problem w/ 809A configurator
problem...
out how to fix it?
Thanks, John
work under 809?
Chuck Andrews
One Forge Road
570-476-8800 Ext 14
Controller@...
_____
JohnBob
problem...
out how to fix it?
Thanks, John
