Problem with ethernet cards
At 01:48 PM 7/26/2003 +0000, you wrote:
>We have the following problem- we had a licensed software (design software
>PROE) on a old computer which reads the adapter card number. We changed
>the computer and installed the card from the old computer
I've messed with the licensing on Pro/E and it can be a royal PITA. If
you're on maintenance with PTC, they're pretty cooperative about giving out
new codes when you upgrade hardware [as long as you're not asking, like
every other week ;) ] It's best to set it up on a central server, rather
than an individual workstation.
Try running both NICs. You shouldn't have to enable & disable them ,
though. Give the Pro/E card a private network address, like 10.X.X.X or
192.X.X.X (that your LAN is not using) and ONLY bind TCP/IP to it. Set up
your other LAN stuff on the 2nd card. Lem'me know how it works.
-Wayne Cox
Twenty Three - Information Technology Consulting
828-685-2338
This does not pertain to Vantage but i would appreciate any comments
on the following
Ethernet adapter cards:
software PROE) on a old computer which reads the adapter card number.
We changed the computer and installed the card from the old computer
along with the new onboard card. We would disable the old card when
connecting to the network and the Internet whole enabling the onboard
card. To use PROE we would disable the onboard card and enable the
old card. It worked for a few days but now we are unable to use PROE
as the license is having a problem with the cards.
Can anyone throw some light on how to resolve the above?
If you want to reply offlist and tell me what the error is youÂ’re getting, I
Â’ve got quite a bit of workarounds with PROE.
Terry L. Williams 176 Shadywood Circle Cranberry, PA 16319
814-676-8650 tlw@... <mailto:tlw@...>
Sent: Saturday, July 26, 2003 9:49 AM
Subject: [Vantage] PROBLEM WITH ETHERNET CARDS
on the following
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=17050071
83:HM/A=1652964/R=0/SIG=11t2ts2ch/*http://www.netflix.com/Default?mqso=60178
276&partid=3170658>
