In 8.03, in the Mass Issue to Mfg screen once you have pressed the 'Issue All' button, you can scroll across the screen to find a 'Qty Issued' box. For those items that have 0 quantity, enter 0 in this box instead of the value that is required for the job. This way you will not have negative inventory. You can do this for partial issuances as well where you are only able to give out a partial amount instead of the full amount required by the job.
--- In vantage@yahoogroups.com, Sreejith Jaganathan <sreesvantagedoubts@...> wrote:
> Good Morning;
> Kindly somebody help me to sort our the issue. As per the company policy negative stock is not going to be accepted.
> Regards
> Sreejith J
> From: Sreejith Jaganathan <sreesvantagedoubts@...>
> To: Vantage Group <vantage@yahoogroups.com>
> Sent: Tuesday, September 25, 2012 3:28 PM
> Subject: [Vantage] Problem with issuance of material
> ÂÂ
> Good Afternoon;
> We are facing a problem related to material issuance.
> Let me explain the problem
> 01. Negative stock is not allowed so the setup is done on the Part Class.
> 02. For issuing the material against a job we use the transaction MASS ISSUE TO MFG
> 03. When we click on issue complete it gives a message [4 Stop Actions Exist Unable to Continue].
> 04. After checking the issue list i found that there are 4 items which contains 0 on hand qty.
> Please do let me know how we could issue the other materials which are there in the stock using the transaction [MASS ISSUE TO MFG]
> Regards
> Sreejith J
