Problem with Query
Sorry I didn't meant to be cryptic. It was bolded, I forget this list is plain text. Glad it helped.
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tim Dines
Sent: Thursday, December 01, 2011 2:28 PM
Subject: [Vantage] Re: Problem with Query
Adding MFGSYS fixed the issue. Thanks a bunch for the quick help on this issue.
Tim
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...<mailto:kschoenung@...>> wrote:
> FROM MFGSYS.PUB.PartTran PartTran_0
> I think the difference is you are missing MFGSYS
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Tim Dines
> Sent: Thursday, December 01, 2011 3:23 PM
> So this is a formatting issue? Can I use a format string rather than an exact date to make this work?
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@<mailto:kwilliams@>> wrote:
> > I had this same problem, ONLY with the PartTran table. Fortunately I documented it :).
> > Note the difference between these two:
> > Broken:
> > SELECT PartTran_0.TranNum
> > FROM PUB.PartTran PartTran_0
> > WHERE (PartTran_0.TranDate={d '2010-03-30'})
> > Working:
> > Ken
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Tim Dines
> > Sent: Thursday, December 01, 2011 2:07 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Problem with Query
> > I am trying to do what I think should be an easy query, but having no luck. Version is 8.03.408b on Progress 10.1b
> > SELECT PartTran_0.PartNum, PartTran_0.TranDate, PartTran_0.TranQty
> > WHERE (PartTran_0.TranType='MFG-STK')
> > ORDER BY PartTran_0.TranDate, PartTran_0.PartNum
> > When I attempt to save or run this query the error message says,'Syntax error in SQL Statement at or about "Systime, PartTran_0.Sysdate,PartTran_0." (10713)
> > Does anyone know how to get around this issue? This query doesn't even use Systime. Thanks for your help.
> > Tim Dines
Tim Dines
Where are you running this query from ODBC?
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
> Tim Dines
I just ran that exact query on my side ODBC and it worked fine...
I also removed the Alias,...
SELECT PartTran.PartNum, PartTran.TranDate, PartTran.TranQty
FROM PUB.PartTran
WHERE (PartTran.TranType='MFG-STK')
ORDER BY PartTran.TranDate, PartTran.PartNum
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> Tim Dines
Yes. It is an ODBC query from Excel. I do quite a lot of these without issue.
> FROM PUB.PartTran
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> >> Tim Dines
Broken:
Working:
Ken
Tim Dines
> Broken:
> Working:
> Ken
> Tim Dines
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@...<mailto:kwilliams@...>> wrote:
> Broken:
> Working:
> Ken
> Tim Dines
Tim
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@<mailto:kwilliams@>> wrote:
> > Broken:
> > Working:
> > Ken
> > Tim Dines
