Problem with Zebra printer & shipping label
Brent,
I used to get this error also running Win 95 or Win 98 and printing
customized shipping labels. We have Zebra 105se label printers. Is Zebra
S-500 the default printer when you are working on the "Shiplabl.rpt" in
Crystal Reports? If not make it the default, at least until you finish
working on the labels and save it. The client does not have to have it as
the default printer. Is the printer driver set to the correct label size and
orientation? Make sure none of the text runs outside of the margins. Also
check the size and the modified date of "crpe32.dll" file if it's the same
as on other clients.
Let me know if this helps.
Mike Tonoyan / MIS Manager
All American Products Co.
1135 Aviation Place
San Fernando, CA 91340
USA
Tel.: 818-361-0059 Ext.: 246
Fax 818-898-2236
E-mail: miket@...
Web: www.allamericanproducts.com
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, April 18, 2002 8:34 AM
Subject: [Vantage] Problem with Zebra printer & shipping label
> We just purchased a computer with Windows 2000 SP2 and I am trying to
> hook up a Zebra S-500 thermal printer to it. I downloaded the latest
> driver from Zebra and installed it but got the following error -
> "Digital signature not found" - and something to the effect that
> Microsoft has not approved this software.
> However, I was able to successfully install the printer and print a
> test page. I then tried to print a customized shipping label in
> Vantage and received error 997 and "Could not load DLL procedure
> crpe32.dll (3258)". I received this same error when I tried to print
> the default shipping label.
> I called Epicor and they told me to try different drivers, which I
> did such as the S-400 and S-300, but none of them were successful.
> I also hooked up an HP Laserjet 2100 to this computer and was able to
> successfully install it and print a shipping label in Vantage.
> However, the left and top margins were a little truncated.
> Does this mean that windows 2000 requires all the forms to be
> redesigned or some of the DLLs to be replaced to work properly with
> Vantage?
> We are currently on Vantage 5.0.337 and use Crystal v8.0.
> Brent O'Donnell
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Vantage?
Brent O'Donnell
