Procedure editor commands
Thanks Carl,
That worked great!
Jasper
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Carl Peterson
Sent: Friday, March 28, 2008 8:28 AM
Subject: RE: [Vantage] Re: Procedure editor commands
Jasper:
The parameters cannot contain spaces or the program will abort.
Listed below is information from Progress on the -param statement. The
passed parameters need to be parsed in the receiving program. This
technique can be used to execute your Vantage 6.1 reporter files.
Good luck,
Carl Peterson
1-734-453-3101
Plymouth, Michigan
Title: "How To Pass Parameters From The Command Line ( -param )"
Created: 09/13/1999
Last Modified: 01/25/2008
Status: Verified
Goals:
. How to use the -param Session Parameter with a list of entries?
. Session Parameter -param and entry list
. Using the -param parameter to refer to a list of values
. Passing a single character string with -param
. Passing a parameter containing spaces with -param
. Converting the character parameter to another data type with -param
. How to pass parameters from the command line (using -param ) to 4GL
. This technique can be used to pass parameters to a Progress application
that needs to behave differently based on some few parameters, or batch
programs that needs parameters.
. How to use -param?
. Can a startup procedure have parameters?
. How to deal with -param value in the code?
. What is the -param startup option?
. How to pass parameters from the command line ( -param )
Facts:
. All Supported Operating Systems
. Progress 8.x
. Progress 9.x
. OpenEdge 10.x
Fixes:
This Solution describes how to pass parameters to Progress from the command
line to a 4GL program.
This technique can be used to pass parameters to a Progress application that
needs to behave differently based on some few parameters, or batch programs
The -param parameter can be used to pass a character string to a Progress
session.
The SESSION:PARAMETER attribute can be used to access this character string.
This character string can be converted to another data type or parser as
required by the application.
The -param parameter can be used with any Progress client, examples:
- prowin32 -p pp.p -param test
- _progres -p pp.p -param test
- pro -p pp.p -param test
- mpro -p pp.p -param test
- bpro -p pp.p -param test
- mbpro -p pp.p -param test
Example of usages:
1) Passing a single character string:
- Test program (pp1.p)
DISPLAY "The parameter is:" SKIP SESSION:PARAMETER FORMAT "X(70)".
PAUSE.
QUIT.
2) Passing a parameter containing spaces:
- prowin32 -p pp1.p -param "test abc"
- Test program (pp.p)
PAUSE.
QUIT.
3) Converting the character parameter to another data type
- prowin32 -p pp1.p -param 1024
DISPLAY "The result of the parameter + 70 is:" SKIP
INTEGER(SESSION:PARAMETER) + 70.
PAUSE.
QUIT.
4) Using the -param parameter to refer to a list of values
- prowin32 -p pp1.p -param abc,xyz,123,789
DEF VAR c AS CHAR.
DEF VAR i AS INT.
c = SESSION:PARAMETER.
c FORMAT "X(70)" SKIP
"The number of entries is:" NUM-ENTRIES(c).
REPEAT i = 1 TO NUM-ENTRIES(c):
DISPLAY "Entry: " I " is " ENTRY(I, c).
END.
PAUSE.
QUIT.
Notes:
The client parameter -param can also be used to specify one or more files to
load into the Procedure Editor buffers when starting Progress.
Therefore, if the -param value does not correspond to a file or you do not
want the Procedure Editor to load, you can use the QUIT statement so the
program will finish without opening the Procedure Editor.
References to Written Documentation:
OpenEdge Deployment: Startup Command and Parameter Reference, "Parameter
(-param)" entry
OpenEdge Development: ABL Reference, "PARAMETER attribute" entry
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
locper99
Sent: Thursday, March 27, 2008 2:42 PM
Subject: [Vantage] Re: Procedure editor commands
Michael, What format does the parameters have to be?
After my statement, I put this in:
-param Loc, 17000, 10
These paramaters are the Company, Job number, and Operation.
I get an error stating that it can't identify 17000. No matter what
I do, it can't identify any thing after the first paramter.
Any suggestions?
Jasper
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "Podlin,
Michael"
<michael.podlin@...> wrote:
> you can use -param in the command line to pass variables to the .p
procedure.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]On
Behalf Of Jasper Recto
> Sent: Tuesday, March 25, 2008 12:35 PM
> To: Vantage Groups (E-mail)
> Subject: [Vantage] Procedure editor commands
> A while back ago, somebody gave me this command to lauchr report
builder reports using .p files from a script.
> "V:\PRGS91D\bin\prowin32.exe V:\MFGSYS61\db\mfgsys.db -ininame
V:\MFGSYS61\mfgsys.ini -pf V:\MFGSYS61\db\mfgsys.pf -N TCP -H loc-
vntg -S 6100 -ld MFGSYS -p v:\Report Procedures\Production\OpenJobs.p"
> The .p file would have any report filter embedded in it. Does
anybody now if it's possible to pass the report filter in the command
line itself?
> Thanks,
> Jasper
A while back ago, somebody gave me this command to lauchr report builder reports using .p files from a script.
"V:\PRGS91D\bin\prowin32.exe V:\MFGSYS61\db\mfgsys.db -ininame V:\MFGSYS61\mfgsys.ini -pf V:\MFGSYS61\db\mfgsys.pf -N TCP -H loc-vntg -S 6100 -ld MFGSYS -p v:\Report Procedures\Production\OpenJobs.p"
The .p file would have any report filter embedded in it. Does anybody now if it's possible to pass the report filter in the command line itself?
Jasper
you can use -param in the command line to pass variables to the .p procedure.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Jasper Recto
Jasper
Any suggestions?
Jasper
--- In vantage@yahoogroups.com, "Podlin, Michael"
procedure.
line itself?
> Thanks,
> Jasper
Jasper:
Good luck,
Carl Peterson
1-734-453-3101
Plymouth, Michigan
Created: 09/13/1999
Status: Verified
Goals:
Facts:
. Progress 8.x
. Progress 9.x
. OpenEdge 10.x
Fixes:
session.
Example of usages:
PAUSE.
QUIT.
PAUSE.
QUIT.
PAUSE.
QUIT.
DEF VAR c AS CHAR.
DEF VAR i AS INT.
END.
PAUSE.
QUIT.
Notes:
(-param)" entry
locper99
Any suggestions?
Jasper
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Podlin,
Michael"
procedure.
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
line itself?
> Thanks,
> Jasper
